The solid axle rear end would eliminate the blown u-joints that happen with high HP cars. A Dana 60 or Ford 9" rear end is WAY more heavy duty than any beefed up 12 bolt setup.
You won't have any blown u-joints with this setup, and you will get to keep your IRS.
Last year's Pump Gas Drags fastest time (not the winner) was a C3 that went about 148mph in the quarter (as I remember) with this setup. It's NHRA legal to 7.5!
Why buy a 396 Nova when you can buy a straight-six and hack from there? Nobody(today) buys an L-88 Corvette to back-half it and modify the bajeezus out of the motor. If I wanted to "hack" on any car, I'd pick the base engine. I have no interest in running an engine with L-88 or LT-1 heads on it, much rather slap a pair of modern wonderheads. Odds are I'd use a different block and crank than what was started out with anyways...
...SO... there's that.
Obviously, if someone wants a vette as a base for a dragster, that's his or her choice.
-Steve
Steve: A 396 Nova alread HAS most all of the "goodies" already installed. Starting with a 6 cyl means a full front to back change, and my pockets just aren't THAT deep
Nobody buys an L-88 Vette TO DRIVE anymore anyway
They're all on that auction show on Speedchannel
The Vette has a decent weight, and, except for the rear end, is suitable for drag racing. Since mine came with a big block, I really don't have to make a lot of mods to the car. But that rear end...it's BAD NEWS
Z-Man: ALWAYS follow the money trail. Are there any ads in that magazine for Tom's Differentials? I'm betting there is. Endorsements like that are always suspect when the product being endorsed is ALSO paying for advertising.
Even if that COSTLY rear end does hold up (was it installed in a stick or auto?), you still have the flimsy u-joints that can let go.
I don't WANT to keep that IRS!!! A solid axle rear end has other advantages...especially a Ford. The drop out carrier makes it VERY easy to change rear axle ratios.
Dep - Forgive me, my knowledge of the Nova's components isn't very significant.
If I had my choice, I'd own a GT40 (old, not the new 3500 lb gargantuan) for track days. Kit car so if it wrecks, I don't cry too much and also don't have half the Ford heads in the world hating me for such an act of indiscretion.
-Steve
Steve: I watched a special yesterday on the Shelbys. Man...I'll take that 427 King Cobra!!!!!! No kit...the REAL DEAL!!!!
I am also not crazy about the new GT40. Would prefer the old version.
Dep: ERA Replicas sells a GT40 kit that uses C4 Corvette suspension and weighes 2400 lbs (Read, miata weight) with an IRON head 351-W. The only scary part is the transmission(transaxle)- a Renault I believe. $5K used. More like $10k for a like new one.
Dep
Oh, I see. I was just pointing out that the U-joints were good to over 1200hp according to the article. Tom's doesn't make the U-joints.
Z-Man: Certainly there are u-joints that can take abuse. Heck, there are at least two on normal rear wheel drive cars. The problem with the Vette is the up and down change in geometry and the increase in "weak links" of having 6 instead of two. I just want to eliminate those weak links, plus get the heavy duty advantage/convenience of a Ford rear end. Did the article mention if the car was stick or auto?
Stick cars are notorious for blowing out u-joints.
I think its a cool idea and I am looking at doing it myself. My brother-in-law builds race cars and has already done 2 C-4s and a C-3. We have already talked about it and he is going to help me. It looks awesome. As for now I have just started collecting parts.
Dep -
I have an acquaintance that drag races a '67 big block A/SA.
He's got a 9" Ford in it with the tranverse spring and different trailing arms. I don't believe he made any significant modifications to the frame and/or body. I'll call him and see what I can find out about it and let you know.
havent TUBS for vettes been around for a little while? it may be a impossible task for most people, but i think its do-able. you could even mini tub it. and yes i know it would be far from a bolt in because you would have to move the frame rails. but a mini tub seems fairly easy. lets see, maybe some bolt on brackets to hold top of a coil over, bolted to the inside of the framerails, and a modified ladder bar type set up that bolts to the stock trailing arm location, and offsets towards the diff. and a panhard bar to keep it centered. simple. you wouldnt even have to move the framerails with this setup.
well i'd sure be interested if you figure something out. i just got off the phone with compitition products and the conversion to straioght axle isn't going to be easy or cheap.
Jeff: Just read the PM and it sounds VERY encouraging!! I had a feeling there WAS a way of doing it. Just don't have the grey matter to figure out the "how". I will be contacting your friend when the time comes for that switch.
panchop: Most shops don't want to put in the effort (or brainpower)involved in doing a conversion of this type. It's easier (for them) to back half it and install a 4-link solid axle. And yes, it AIN'T cheap!!!!
Welcome back Dep! Good to see you are still out there and thriving. I am not technically competent to make a contribution to this thread. Just wanted to say Hello!
Dep
ok, how much is a tub kit? fatman fabs will sell you one for under 2000, and thats everything but axles, brakes, wheels and tires. but id bet the body mods would kill ya just because of the fiberglass. i can fab my azz off, but im scared of glass work. i garantee, i could have new balkhalve frame rails in on a weekend. but wouldnt have a clue how to mod a fiberglass body. id have to pay big $$$ cause i couldnt do it myself. but MAAAANNN! a tubbed c-3 is the sweetest thing on wheels. .02 jack
