I have seen it a few times on the forum. It has 8 individual intakes where they cross over and have individual filters they go to the side like the fiat weber setups.
FYI that Intake is for IDA Webers . I do not think you want to price 4 of those much less have to dial them in. Much less find all the jets you might need to do it.
I am pretty sure you can check with a company by the name of Fuelish that will have what you want if that is the direction you are looking. If you do go that rout they will be time consuming to set the carbs up but once they are you will have throttle response that will be very close to Fuel Injected or atleast as close as you can get with a carb.
i just like the setup, i think it would be cool. what's it run about 1500 for everything? i don't mind tuning, neighbor has some neat tools for it. His bike runs 4 individual carbs.
Oh yeah you're right, the barrel spacing is larger on the IDAs forgot so only IDAs on that on, be prepared to break the bank for 4 of those The DRLAs won't fit then either.
... I used to have 4 IDF 48 XE's..brand new and a set of DRLA 48s...never could get my hands on the required manifold (cheap) so I sold them.
