Pull engine with or without tranny attached
Old Feb 12, 2005 | 08:46 PM
stingray_jim's Avatar
stingray_jim
Default Pull engine with or without tranny attached
I've got everthing pretty much detached. Now the question is what makes the most sense. I have the radiator out, linkage unhooked, and the speedo wire, driveshaft etc. It seems to me pulling the engine and tranny together makes the most sense. By the way it is a mess by the frame cross member. What is the best way to unhook the tranny from the frame. There appears to be a plate just behind the linkage that bolts to the frame. I figure unbolting the plate is the way to go.
Thanks,
Jim
Old Feb 12, 2005 | 08:49 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
To pull the engine might be easier without the tranny attached..
Old Feb 12, 2005 | 09:01 PM
carhound's Avatar
carhound
It is really hard to pull both at one time. When I pulled mine, I pulled the trans. first, then I pulled the motor. When I put it back, I put the moter and the trans together and I could not get it in, so I took them apart and put the moter in first and then the trans. To leave the trans in, especially if you are working by yourself, is hard to get everything lined up. I put the motor in and then used a floor jack and jacked and rolled it right into place with no prob at all.
Old Feb 12, 2005 | 09:08 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
When I pulled mine, I pulled the motor first and then the tranny. Later when I put it all back together, I put them in as one.
Old Feb 12, 2005 | 09:09 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
When I did my '75 engine/tranny replacement-I took the motor/tranny out together & put back in the same way. I also, had my radiator & coresupport out, so that did give me more room.
Old Feb 12, 2005 | 09:11 PM
68/70Vette's Avatar
68/70Vette
What year is your car. Do you have a manual or an automatic transmission?
If's like my early C3 (1968 or even a 1970) just unbolt the transmission crossmember attachment bolts. Unbolt the shifter rods at the tansmission housing. (The shifter and rods will stay in the car. They're attached to a bracket that's bolted to the diff crossmember.)
I prefer to lift out the engine/bellhousing/transmision stack as complete assembly. This requires a hoist with a tilt bar. I think some people in this forum will just prefer to remove the transmission by itself.
Old Feb 12, 2005 | 09:47 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
IMO, it's easier to install as one unit than remove as one unit.
Old Feb 12, 2005 | 10:14 PM
princeRed72's Avatar
princeRed72
I had the radiator removed also but the front end still on the car. I tried to pull both together but it would not go. The book even states remove as separate units.
To Pull engine with or without tranny attached
