Performer Air Gap
Old Feb 17, 2005 | 07:43 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I had the RPM Air Gap on my 355ci
and a Vic Jr. on my 406ci both fit under my stock '80 hood
Old Feb 17, 2005 | 07:54 PM
Mr Fanuc's Avatar
Mr Fanuc
Originally Posted by Fireslayer26
Ok, I guess I'll just have to stick with the Performer non-airgap.
Get a can of playdough, form into a ball and put it on the front of the air cleaner, slam the hood, raise the hood and measure the height of the playdough. Air Gap RPM and Performer RPM are the same height, 1.050" taller than stock. If you have that much clearance it will fit.
Old Feb 17, 2005 | 11:03 PM
Fireslayer26's Avatar
Fireslayer26
I will try that. Just have to go to Toys-R-Us and get some playdough now!
Old Feb 18, 2005 | 09:27 AM
JHL81's Avatar
JHL81
Should maybe clarify, when I originally fitted the Airgap I did have it under the hood with a drop base but a very thin filter, at the time I tried to get one of those K&N lids but they were hard to come by over here in the UK then.
The problem I had was that I felt the motor just wasn't giving it everything, from a run on a chassis dyno with the old set-up then a return run with the scoop, the engine found 20hp and that was with relatively hot air in an enclosed bay in the shop where the dyno was, might be a bit more in nice cold air driving on the open road.
J.
