Aluminum vs. Copper radiator
Old Feb 14, 2005 | 09:04 AM
isosceles's Avatar
isosceles
Default Aluminum vs. Copper radiator
Besides the obvious weight savings, will a (typical) 2 row aluminum radiator offer noticeably better heat dissapation than a 4 row copper radiator?
Has anyone changed ONLY the radiator (no fan changes) and noticed a difference? Was is 2,3 or 4 row aluminum?
Old Feb 14, 2005 | 09:09 AM
Willis's Avatar
Willis
I noticed a large cooling difference when I changed out the stock radiator on my 81 with a 2 core aluminum. However, the stock radiator on an 81 is not a 4 row, it's only a two row. I definitely like the way the aluminum looks though. You can polish it if you're crazy enough.
Old Feb 14, 2005 | 09:50 AM
norvalwilhelm's Avatar
norvalwilhelm
I really like my 2 row aluminum rad and even with my blown big block I have absolutely no cooling problems, even to the point of turning off all the electric fans and still maintain about 180-190 operating temperature.
The advantage of aluminum is that they can make the cooling tubes larger, alot larger up to 1 1/2 inches.
Mine is a 2 row 3 inch rad with 1 1/2 inch tubes.
The copper the tubes are about 1/2 inch to prevent blow out and by aligning 4 or these they get the 4 core rad but there is a problem is alignment and thus air flow restriction with missalignment.
I would definietly go with aluminum.
To Aluminum vs. Copper radiator
