Composite Spring ?
Old Feb 15, 2005 | 12:17 PM
Hvymtlc5's Avatar
Hvymtlc5
Default Composite Spring ?
For bracket racing do I need more rear composite spring tension (355) or softer (315) so the car will squat? And, it looks like TRW is NOT the way to go if I want lower ride height - right?
Old Feb 15, 2005 | 12:20 PM
tshort's Avatar
tshort
CI 7-8 Veteran
You want more. More horsepower requires more grip. More grip requires stiffer spring. You're also trying to limit the angle on the half shafts if you don't want to bust u-joints.
Old Feb 15, 2005 | 12:34 PM
Hvymtlc5's Avatar
Hvymtlc5
Makes sense... thanks
Old Feb 15, 2005 | 03:29 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
I would go w/the dual mount rear spring if your autocross racing.
Old Feb 15, 2005 | 04:08 PM
73jst4fun's Avatar
73jst4fun
I agree with tshort....
Old Feb 15, 2005 | 07:51 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
and cheaper than having several different springs.
Dual mount is all in one
To Composite Spring ?
