78 wiring problems.....
Old Feb 15, 2005 | 02:34 PM
rcastor426's Avatar
rcastor426
Default 78 wiring problems.....
ok, i have had my 78 pace car for about a year, it has always had some sort of electrical issues... windows, would not work..heater would not go to high. so i just put in a new engine now it driains the battery and i had no heater fan at all. so i changed the relay in the engie compart ment, with the car off and key off the new relay turned the fan on low????? now should i assume a bad ignition switch and replace or a defective fan realay?
Old Feb 15, 2005 | 04:10 PM
72GACRZR's Avatar
72GACRZR
Do you have a wiring diagram? It could be the relay was wired wrong or a short is allowing power to it. I think your car is one where the fan should be running on low whenever the car is running, so check the wires at the relay with a meter and see if the one from the ignition is hot when all is off. You will need that diagram.
