Bearing and u joint ?
Old Feb 16, 2005 | 10:52 AM
sedowney's Avatar
sedowney
Default Bearing and u joint ?
1.Have any of you replaced the half shaft u joints, is it a pain?
2. what about replacing the rear wheel bearings, PITA also?
I think I will buy them from muskegon, since they are a sponsor. Also it is tough to beat the price
Old Feb 16, 2005 | 11:16 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
The half shafts are easy to remove and it's a piece of cake to replace the U-joints. I have not worked on the wheel bearings yet (and hope that I don't have to any time soon)...
Old Feb 16, 2005 | 11:27 AM
Magnet's Avatar
Magnet
Hi there,
The 1/2 shafts are east to remove and replace.
The rear bearings are a little more challenging, but can be done. The 2 challenges are that you will have to drill out the 3 small studs that hold the rotor on, that is if the rotors have never been removed. The second challenge is the inner rear wheel bearing may be stuck to the rear stub shaft. If this is the case, to remove the stuck inner rear bearing from the shaft you will need a slide hammer and a wheel bearing tool or torch. These wheel bearing tools are costly, but I remember a while ago that someone had one on the CF tool loaner program. I hope this information helps
Old Feb 16, 2005 | 11:57 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Originally Posted by Magnet
Hi there,
A torch to remove the inner bearing
There are 5 rivits that hold the rotor on. You'll have to drill them out if they have not been removed already. You have to press out the spindle and press the outer bearing off as well. You will need to buy some tools to do this job yourself and correctly.
Old Feb 16, 2005 | 12:22 PM
GTR1999's Avatar
GTR1999
If you have never worked on a corvette before be prepared for the unusual. They are not like working on other 60's -70's cars.
The joints in the driveshaft aren't too bad but the 1/2 shaft joints are tougher. Don't expect a bench vise to press them out and you must support the flange when working on them or you'll wreck it for sure. If you have a torch cut them out with it or even a die grinder.
Rear bearings are not hard but critical to setup. You should set them to .001-.002 end play and get the rotor runout under .003" You will need some special tools and experience. If you ever worked to close tolerences as toolmaker, machine repair mechanic, or machinist they are "cake" if you aren't experienced with bearings I suggest you send them out. I do couple for club members maybe you're in a club with an experienced guy there? Van Steel or Bairs can also do the job and do nice work.
You may find it hard to remove them from the car. I suggest you do a search here because these jobs have been talked about on a weekly basis since I joined in '99
Good luck,
Gary
Old Feb 16, 2005 | 12:26 PM
MsVetteMan's Avatar
MsVetteMan
autozone has pullers you can rent for free!! It's a tough job and I had to take my spindle into a shop to get my outbearing cut off. I let them press everything back together, and check the play. Getting ready to put in back on.....I will only spend about 90 bucks total including the cost of new bearing parts.
Like any repair...how much is it worth to you? Check the prices if someone else does the whole job.
Old Feb 16, 2005 | 01:29 PM
mandm1200's Avatar
mandm1200
Good luck,
Gary
I think Gary gave the short, quick, accurate version. These jobs are more than do-able by many mechanics. You got to have mechanical skills or at least know someone who can help if issuses arise. Proper tools are essential for replacing the wheel bearings. A torch is not necessary but others refer to it as the 'hot wrench'. There are several great post in regards to replacing wheel bearing. I would read them and see if this is something you want to take on or look for a qualified shop to do it. Many shops do not have the tools or the knowledge to replace wheel bearing on the C3 vette.
Old Feb 16, 2005 | 01:34 PM
sedowney's Avatar
sedowney
Thanks to all who replied. I will try the u joints. And call in an expert on the bearings.
To Bearing and u joint ?
