CD player installation question - Please help!!!
Old Feb 7, 2005 | 03:05 PM
68coupe's Avatar
68coupe
Default CD player installation question - Please help!!!
UPDATE - check page 2 for an update with PICS
Hello everyone,
I am currently in the process of installing a cd player in my 68 vette. I have removed the gauge cluster bezel and I am stuck!
Here is my question for you. What is the easiest way to cut the bezel? The thing is made out of metal and it does not seem like an easy thing to do. I have a very limited tool selection. I know that companies make new bezels, but the 1968 version is $250 (if you know of a place that is at least $150 cheaper, let me know) and I would rather just cut mine and save the cash. (It has already been slightly modified (drilled) to fit an aftermarket tape player, so it is worthless anyway) I have seen loads of people change over to an in-dash (din sized) cd unit, how did you guys go about doing it? Are there any tricks? All suggestions welcome!!
Thanks,
Joe
Old Feb 7, 2005 | 03:13 PM
NC C3's Avatar
NC C3
Sounds like the job for a dremel tool to me. They only cost about 50 bucks and the uses are endless!! good luck
Old Feb 7, 2005 | 03:20 PM
R. Bruno's Avatar
R. Bruno
Thats how I did and with a small hacksaw. You can get a plastic cover sort of thing that goes over the installation that really cleans it up also. I ordered it from somewhere in Georgia at the suggestion of someone on the forum.
Old Feb 7, 2005 | 04:01 PM
BreauxBridgeKid's Avatar
BreauxBridgeKid
Default Dremel
I used a Dremel and use the carbon fiber wheel....takes a while to get it exact but not hard just painstaking. Definatly doable alone. Good luck.
Paul
Old Feb 7, 2005 | 04:06 PM
zwede's Avatar
zwede
I used an angle grinder with a cutoff wheel to cut most of it and finished (the corners) with a hacksaw. You can find a cheapo angle grinder for $20.
I recommend you get the plastic cover plate as it really cleans up the installation.
Old Feb 7, 2005 | 04:08 PM
68coupe's Avatar
68coupe
I purchased the plastic cover you are speaking about. I got it online $13 bucks including shipping. I already received it in the mail and it looks good. I think I am going to start with the hacksaw and finish with a dremel. small hacksaw? how did you get it in the tight spaces? I originally though that I would only be able to use the blade and not the entire tool because of the cuts required and the tight space. How did you get a hack saw in there? Can you give me a little more detail related to how exactly you cut it and some more detail about the smaller hacksaw you used.
Thanks for your help,
Joe
mrtroutjedi's Avatar
mrtroutjedi
I used a sawzall on the bench
Old Feb 7, 2005 | 04:13 PM
68coupe's Avatar
68coupe
Really?
Was it a messy cut? Hard to control?
Did you just put it in the vice and go at it?
I thought about using that, but I thought it would be to difficult with the confined space.
Thanks,
Joe
Old Feb 7, 2005 | 04:16 PM
68coupe's Avatar
68coupe
Default Jigsaw?
What about a jigsaw with a blade made for metal cutting. I think that tool would be easier to control than a sawzall and has the characteristics to cut in the confined space.
What do you think?
Thanks,
Joe
Jay M's Avatar
Jay M
Originally Posted by 68coupe
Hello everyone,
Thanks,
Joe
I wouldn't cut a '68 bezel!!!
those are unique and expensive to replace if you ever decide to go back to stock.
I would call some corvette junk yards and find a bezel that has already been cut. A used cut bezel is only $50. I you really don't care about your bezel, then sell it for $200 (assuming it isn't broken) and buy a used pre-cut bezel.
~Jay
Old Feb 7, 2005 | 04:19 PM
68coupe's Avatar
68coupe
~Jay
Jay,
Thanks for the suggestion but the bezel is broken in half and it has already been cut to fit an aftermarket tape player. I know how tough they are to come by. I wish it was in good shape, but it is really kind of a piece of junk.
Thanks,
Joe
Old Feb 7, 2005 | 04:22 PM
73'Vette's Avatar
73'Vette
This method works. It's how I did mine.
Old Feb 7, 2005 | 04:28 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I used a jigsaw and a metal blade to cut mine. I also used a file to make the final fit nice and tight for the cd player. Not too bad. Just mark out your pattern to cut by on the back of the bezel and have at it.
Old Feb 7, 2005 | 04:51 PM
68coupe's Avatar
68coupe
Sounds good!
I gett the cd player on Wednesday, I will start working on it then. I will post some pictures of the progress.
Thanks,
Joe
Old Feb 7, 2005 | 05:01 PM
COMMANDER370's Avatar
COMMANDER370
Paul
Dremel
Old Feb 7, 2005 | 06:44 PM
burnz27's Avatar
burnz27
What do you think?
Thanks,
Joe
I used a jigsaw and some files before, now I would probably use a dremel (because I have one now).
Old Feb 7, 2005 | 09:57 PM
redwingvette's Avatar
redwingvette
I am in the middle of doing thi myself. I used an air grinder with a cut-off wheel and it worked great. Radio install
To CD player installation question - Please help!!!
Old Feb 7, 2005 | 10:44 PM
Todd68's Avatar
Todd68
I also used an air grinder with cut off wheel. I made my own bezel out of sheet steel. Made a pattern, cut out, bent all the sides, then welded. It fits into the hole I cut into the original bezel, and is screwed in from the backside. Very solid. Of course, after all that, I found the ready made version was available! Here's a pic:
BTW: Next interior project for me will be replacing the missing seat belt warning switch & refurbishing console & dash panels! Also, if you are using pre-outs to an amp, I found some cables with right angle connectors helped the close fit at back of head unit / heater.
Old Feb 7, 2005 | 11:14 PM
rosslato's Avatar
rosslato
thanx everybody for showing me the way, i'm getting ready to do that myself in about a month
Old Feb 8, 2005 | 10:52 PM
blackbeauty74's Avatar
blackbeauty74
Where did you fing that kit online for $13.00,
thanks
