Last night we began degreasing and powerwashing my 69 rear end for a planned rebuild. While powerwashing the half shafts and differential, I noticed that the half shafts are different sizes!!! The left shaft appears to be 2 1/2" and the right seems to be a 3" in diameter.
Obviously, the right shaft was replaced at some point prior to my purchasing the car. My mechanic and I debated the issues that might arise from two different shafts being installed (unbalanced???). From my stand point, I will need to drive the car to determine if there is any noticable difference. Has anyone encountered this before?
The 75+ and service replacements were 3" and the 63-74 were 2.5" If I recall correctly. You shouldn't have a problem but check the yoke area to see if they were crushed when Bubba replaced the joints years ago.
Gary
I hope to have the old parts out on Saturday. We will pull the differential (mechanic calls it the "ham") and give everything a good once over. Thanks.
