78 exhaust question
Old Feb 20, 2005 | 10:03 AM
gh78's Avatar
gh78
Default 78 exhaust question
since I am having my car re-built due to an accident last fall, I decided to have true dual exhaust installed (less the cat) 2 1/2 in. Dyna-flow mufflers. Do I need an H pipe or run them both back seperate to mufflers?
Old Feb 20, 2005 | 10:14 AM
soxx35's Avatar
soxx35
either or would work fine with the h pipe you will get alittle more low end power. Also it will smooth out the exhust tone and quiet it down alittle. In my opinion also if you have a stock engine and are not going to do any major mods i would go with the 2 1/4 inch exhust instead. the 2 1.2 might flow too well.
rj
Old Feb 20, 2005 | 11:42 AM
C3Muscle352's Avatar
C3Muscle352
i have a '78 and opened it up to a true dual, i got about 30hp increase, and it was noticibly faster. I dont have an h-pipe althought people have reccomended that i either make or buy one because it gives you more horses/torque in the lower rpm. So if you had the option to do it now, i would go with the H-pipe.
Old Feb 20, 2005 | 11:53 AM
gh78's Avatar
gh78
Thanks! I'll talk to the shop tmorrow about including the H pipe
Old Feb 20, 2005 | 12:26 PM
mvftw's Avatar
mvftw
I have a stock L82 and went with true duals 2 1/4" H-pipe and Flowmaster 50's . 2 1/4" is better then 2 1/2" for a stock motor...
Old Feb 20, 2005 | 02:48 PM
C3Muscle352
i thought the stock size was 2.25 ? i went 2.5 because 3 would just be too big. What kind of performance increade did you get mvftw ? my esp fly hp is 224 from the stock 185 and the exhaust is all i have done.
Old Feb 20, 2005 | 02:54 PM
gh78's Avatar
gh78
we went with inlet size on muffles which was 2.5 but what is odd is that outlet is 2.25
Old Feb 20, 2005 | 06:19 PM
DRKCYDE's Avatar
DRKCYDE
Cruise-In VII & IX Veteran
I would love to know how much that is going to cost you. I am thinking of getting the same setup.
Old Feb 21, 2005 | 10:19 AM
mvftw's Avatar
mvftw
Stock was 2 1/4" but that was with a 'Y' pipe, when you go to true duals you are adding about 6' of pipe, thats the difference...that's why 2 1/4" is better for close to stock engines...
Old Feb 21, 2005 | 12:41 PM
C3Muscle352
why would longer pipe be better? i was thinking about just runing dumps off my headers.
Old Feb 21, 2005 | 01:23 PM
den(thevetteman)78's Avatar
den(thevetteman)78
That's what i have on my '78 L82, 2½" pipe with no cat and '80's dyno- max muflers.The '80's muflers are smaller and less restrective than the big round muflers. The sound is better. This year i bought a set of headers that i will put on this spring.
Old Feb 21, 2005 | 02:05 PM
C3Muscle352
i did that exact setup except that i used 60s i think. I also got some chrome ceramic headers that im putting on in the next few days, along with changing out my motor mounts from fubber to urathane.
To 78 exhaust question
