Heat Riser Valve
Old Feb 20, 2005 | 04:36 PM
OneBrokenSmile07's Avatar
OneBrokenSmile07
Default Heat Riser Valve
I was getting a very loud popping maybe once every three or four times I took the 81 out on the road. The sound was similiar to a very large rock hitting your windshield at high speeds, because it is Deafening. Sounds like the car is about to blow up.
Someone said that maybe my heat riser valve is getting stuck and then popping, and I couldn't think of any other Problem.
If i disconnected the Vacuum operated Heat riser and plugged up the hose would anything go wrong? I'm assuming I have a vacuum leak somewhere in that valve.
Old Feb 20, 2005 | 07:12 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
The only noise you'll hear from a heat riser is a rattle, when the thing gets worn out and has alot of play in it. It won't make that noise you describe.
On the other hand, a bad divertor valve on the smog pump system would cause exhaust explosions on deceleration.
Old Feb 20, 2005 | 07:15 PM
OneBrokenSmile07
I removed all the AIR and SMOG equipment.
It's a very loud, ear piercing, "Are we going to die" noise.
I can't pinpoint it.
To Heat Riser Valve
