Rear ratio change !!!!
Old Feb 20, 2005 | 10:50 PM
bams12's Avatar
bams12
Default Rear ratio change !!!!
I just removed the rear end from my 80 and I am going to be getting rid of the 3.07 ratio. I am back and forth between the pros and cons of a 3.55 and a 3.74. Once I make my chioce I know that I must also change a gear in my automatic tranny to correspond to the new ratio. Where can I purchase this gear and will they know the appropriate part for my chosen ratio ? Thanx Brent
Old Feb 20, 2005 | 10:52 PM
cruzzin-style's Avatar
cruzzin-style
Are U running an O/D trans & do U have any modifications done to the engine?
Old Feb 20, 2005 | 10:57 PM
bams12's Avatar
bams12
Original 3 speed Th350 and no engine mods as of yet .. Brent
Old Feb 20, 2005 | 11:03 PM
cruzzin-style
OK.......If U don't plan on putting in an O/D trans & if U plan on driving it alot at high speeds, You'll be working your engine to a slow death. If your set on upping that ratio.....go with the 3:55. It's gonna bump up your R's to approx. 800 more at about 65mph. This will be hard on your engine if it stays stock or if it's got high milage. However, a mildly massaged motor casn handle the extra R's. Good Luck!
Old Feb 20, 2005 | 11:04 PM
kevinator80's Avatar
kevinator80
I have never heard of having to change anything in the tranny after a rear gear change. Maybe I will learn something here also.
Old Feb 20, 2005 | 11:07 PM
cruzzin-style
I think he's refering to the speedo gear to have the speedometer & odomoter correct. That would be my guess.
Old Feb 20, 2005 | 11:21 PM
kevinator80
That makes sense. My tire size already shot my reading to heell.
Old Feb 20, 2005 | 11:34 PM
bams12's Avatar
bams12
Is that speedo gear not located at the end of the speedo cable at the transmission ? Brent
Old Feb 20, 2005 | 11:49 PM
Brass Pass's Avatar
Brass Pass
If it's Speedometer Gears you're talking about Dr. REBUILD has them in his catalog. 1961-1981 are listed so you might be in luck.
I know they have a website, but I can't find the URL in the catalog. Try typing "Dr. REBUILD" into your search engine. Or you can call them at (203) 366-1332 for tech and product assistance.
Old Feb 21, 2005 | 05:32 AM
Glensgages's Avatar
Glensgages
Assuming you are running 27" tall tires (255/60R15), I'm figuring (with your current 3.07s) you are turning just over 2500 RPM at 60 MPH:
with 3.55s, it'd be just over 2900, and with 3.73s, it'd be almost 3100.
Old Feb 21, 2005 | 06:29 AM
bertmeister's Avatar
bertmeister
Check out smoke em up.com. There is a section to figure out what RPMs you will be running with different gear ratios. Check out bowling and grippo to see how many tooth gear you will need. Your local Chevy dealer can order whatever tooth gear you need.
To Rear ratio change !!!!
