electrical prob
Old Feb 22, 2005 | 09:41 AM
71redskin's Avatar
71redskin
Default electrical prob
i had my dash apart to fix some gauges and after i put it back together and started it the interior lights wanted to stay on, i fiddled with the **** and they went out but the next day when i went out to crank it there was no juice,,,what did i do? and where should i check?
Old Feb 22, 2005 | 10:12 AM
Boofers's Avatar
Boofers
Sounds like a power line is shorted to ground which drained your battery. Most likely a line that is 'hot at all times' since it happenned with your car off. The place to look is where you last did electrical work.
Old Feb 22, 2005 | 10:14 AM
markdtn's Avatar
markdtn
Either you have a bad headlight switch or you have a pinched and shorted ground for the courtesy lights. GM courtesy lights have 12v to the orange wire always. You get the ground with door open or headlight switch through the white wire.
To electrical prob
