Urgent Help Needed!! Timing problem
Old Feb 22, 2005 | 04:47 PM
C3Muscle352's Avatar
C3Muscle352
Default Urgent Help Needed!! Timing problem
i just removed all the wires from my sparkplugs to change them while i was replacing the motor mounts and installing headers But I forgot to place the wires to remember the timing location or whatever the hell its called.
What is the timing diagram, what wire goes where from the distributor to the sparkplugs
Old Feb 22, 2005 | 04:59 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Typically, the distributer stud facing closest to the front of the engine will be to cylinder #1. then go clockwise around from there in accordance with the firing order. If you are off 1 of those studs, you'll have to turn the distributer a little to get it to be timed right, or you can take out the #1 spark plug, make sure that cylinder is at Top dead center, take off the distributer cap, the distributer will be pointing at the correct location for the #1 cylinder, then following firing order for the rest of the cyilinders.
good luck!
Old Feb 22, 2005 | 05:17 PM
gearheadz's Avatar
gearheadz
As Ruby76 suggested, find TDC (compression stroke) & remove cap, rotor will point to #1. Follow firing order clockwise from #1.
Lesson we've probably all learned or will learn at some point .... mark #1 on cap and label plug wires.... saves alot of time & aggravation!
Mark
Old Feb 22, 2005 | 05:32 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
just remember the obvious ? next... 18436572
Old Feb 23, 2005 | 01:28 AM
C3Muscle352
It Is Done
Old Feb 23, 2005 | 09:03 AM
ruby76's Avatar
ruby76
I used to have that memorized, now I have to look it up every time..
To Urgent Help Needed!! Timing problem
