Holley adjustable jet kits
Old Feb 23, 2005 | 08:39 AM
isosceles's Avatar
isosceles
Default Holley adjustable jet kits
I see that there is an adjustable jet kit available from Holley for my 4150.
Seems like it would be the hot setup for dyno tuning or A/F mixture settings.
Are there any downsides to using it? If not, why don't the carbs come with them?
Old Feb 23, 2005 | 12:22 PM
Matt Gruber's Avatar
Matt Gruber
new carbs are often pretty close
Old Feb 23, 2005 | 01:56 PM
norvalwilhelm's Avatar
norvalwilhelm
I think it is added between the metering block and the carb body adding length to the carb by moving the float bowls out. This causes a problem with the dropped base air cleaners.
Also I found I ran jets around 80 and you had to buy a range of adjustment and with my setup the range was right in the middle of the two ranges.
To Holley adjustable jet kits
