Help me build an engine
Old Feb 23, 2005 | 03:43 PM
Stoge's Avatar
Stoge
Default Help me build an engine
I have an extra smallblock that I would like to build into a powerful street motor for my car. I think it is time to pull the L-82 and original transmission and throw them into crates in storage. I want to drive my car hard without having to worry about destroying the original gear.
The donor engine is a '75 K5 Blazer "Trailer Special" 350 that has been rebuilt one time. The engine was bored 30 over but kept stock crank specs, which I am told makes it a 355cid. The engine ran very strong when I pulled it, but that was 13 years ago.
I would like to have it bored again and go with the vortec heads / vortec intake combo that everyone talks about so much.
So like the thread a couple months ago, I want to spend somewhere between $1,500 and $2,000. I already have an unused rebuilt TH350 to put behind it. My car has 3.55's in the rear. Everything is stock.
So, Vortec heads and intake... what part numbers / where do I find them / what price would I expect to pay?
What cam should I be looking at? I want a decent lope, but good low end *and* be able to wind it up to 5.5 - 6k rpm. Is this possible?
And with that cam, what rocker arms, pushrods, lifters, springs would I need to get?
Is there a good package somewhere that I should be looking at from Jegs, etc?
And the final constraint; since I want a streetable motor, it has to be able to burn pump gas, with a max of 93 octane.
Other miscellaneous:
Will have dynomax headers into true duals, high flow cats, H pipe, and try to locate Borla ProXS mufflers.
I don't know what carb to go with, but I would think a demon or Hollley maybe? I'm assuming a quadrajet is out of the question due to the vortec intake.
My extra transmission has a low stall speed TC *I suspect*. May need a new one for the new set-up.
Old Feb 23, 2005 | 04:27 PM
grayhook's Avatar
grayhook
i was looking at doing the same thing, after add'n up all i needed for the vortec setup it was only about $200 more to go with the holley sys. max 2 setup with alum heads, kit made to work together take'n the guess work out of what works with what and what dont. this kit is make'n 400+hp and tq, that was about what i was after so jumped on it
good luck with what ever you go with
Old Feb 23, 2005 | 04:36 PM
GDaina's Avatar
GDaina
Look into a crate motor, 350, 383, and up in cubes
Old Feb 23, 2005 | 04:52 PM
jdunne's Avatar
jdunne
stoge,there is absolutely no substitute for cubic $ if you wish to do it well.....as gdaina said,unless you are very motivated and skilled it is much cheaper to buy someone else,s package...because i thought i was smarter i have finished up spending well over $10,000 on parts for a 383 stroker...mind you,they are the best of everything but man,do they ever add up in price quickly...john
Old Feb 23, 2005 | 07:43 PM
Stoge's Avatar
Stoge
Oh man... so basically I am opening up a can of worms if I go with the build my own motor route... I think if I were to spend that kind of cash I would've had to think long and hard about an LS1 swap... but I bet with $10k you've got yourself a HOT motor.
That holley setup mentioned above sounds nice... but I guess $1000 - $1,500 more than my $2000 goal and I could have a ZZ4.
Hmmmm
Old Feb 23, 2005 | 08:01 PM
Corvus's Avatar
Corvus
Uea go with a crate, by the way the Octane gas useage really depends on your timing and Compression ratio. For higher CR you need more Octane
Old Feb 23, 2005 | 08:02 PM
thebruce's Avatar
thebruce
If you think the donor motor is still in decent shape, why not put a cam in it (something along the 262/268 range offered by Lunati, Comp, etc) and buy the heads/intake you are talking about. You save the cost of a major rebuild, get to try your combo out, and if the engine doesn't survive for long, you can buy a new short block and will only be out the cost of the cam and lifter kit (plus incidentals-- gaskets, bolts, etc.) You will also have the option of a 383 short block at that point if you decide to go that route.
I am still holding off on my 383 or 406 buildup because I am weary of the huge cash outlay to get a drivetrain that can stand up to a bigger engine built right.
Good luck!
To Help me build an engine
