OT Intake comparison for EFI guys
Old Feb 23, 2005 | 05:03 PM
Fevre's Avatar
Fevre
Default OT Intake comparison for EFI guys
Not sure if you guys caught this or not but on another board I found this post:
http://www.thirdgen.org/techbb2/show...hreadid=273727
Interesting thing to me was the stock TPI #'s, 410 hp and 500 torq out of the 383 , might have been even better with a diff cam.
Old Feb 23, 2005 | 05:18 PM
LemansBlue68's Avatar
LemansBlue68
Didn't read the article but one of the big advantages of EFI (port injection, not CFI) over a carb is the use of a "dry" intake. While the carb requires a manifold that keeps the fuel in suspension in the air flow, this isn't a constraint for EFI. This enables the EFI manifold designer to better tune his manifold to make torque at a low or high RPM and not have to worry about the fuel wetting of the manifold and air-fuel distribution problems. The TPI has very long runners for low end torque that would be a disaster if carburated. EFI also enables the use of larger cams, more overlap, etc. because it doesn't rely on a vacuum signal to meter fuel like a carb. Also, by the very design of the carb it imposes a restriction to airflow which is necessary to meter the fuel flow. It relies on pressure drop to pull the fuel into the air-flow. EFI intake systems can be designed to have very low intake losses by eliminating this restriction.
I still like the "looks" of carbs underhood more than an EFI system, though.
Old Feb 23, 2005 | 05:36 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Yeh, It's hard for us baby boomers to accept change but,.......this put me over the hump.
Bullshark
Old Feb 23, 2005 | 05:39 PM
SuprJames's Avatar
SuprJames
Wow, that makes me pretty good about going with the SuperRam/383 combo I put in my Vette. I saw also in a magazine that Scoggin Dickey was offering a 383 topped with the SuperRam intake and a fixed Accel computer (so it's a bolt-in with no programming required)
Old Feb 23, 2005 | 05:43 PM
Fevre's Avatar
Fevre
Ya that super ram made some super torq, I got a HSR in my Formula now and it rocks for $, I have had a LT1 retro fit intake and stock tpi on the same eng and the HSR is the best all around of the 3.
Old Feb 23, 2005 | 05:55 PM
timbo79's Avatar
timbo79
Now that looks great!!!!
Old Feb 23, 2005 | 06:38 PM
markdtn's Avatar
markdtn
You don't like the visual appeal of a Tuned Port? It is the coolest looking of all the EFI engines to me. Those long runners really make the wow factor irresistable to me!
Old Feb 23, 2005 | 07:40 PM
PatsLs1vette's Avatar
PatsLs1vette
I agree with mark,i really like the tpi look but really want to change to a hsr someday.
To OT Intake comparison for EFI guys
