Suspension question
Old Feb 25, 2005 | 01:44 AM
TXShark's Avatar
TXShark
Default Suspension question
I just did the rebuild on the suspension on my 71 coupe. When I was doing the front springs, there were horseshoe shaped spacers in the lower control arms, about an inch thick. Based on the condition, and the rivets in the upper ball joint, I don't think the front end has ever been apart before. Anyway, I put them back in with my new springs, because I thought they might be required to pad the control arm. Once I got the car back together and on the ground, the front end is an inch too high (go figure). I never thought not to replace them, since I have "extrapartaphobia". Of course, now I will be taking them out as soon as my wounds heal from this last front end foray. Has anyone else seen these? I don't see pictures in any of my books or assembly manual that indicate these should be in the control arms. Anyone have any thoughts or history on these things? Are they factory or dealer, or just some aftermarket thing? It may be from a previous owner who didn't want to replace the sagging springs. Thanks.
Old Feb 25, 2005 | 01:49 AM
Z-man's Avatar
Z-man
I've never seen them before. I think your last thought about sagging springs might be correct...
Old Feb 25, 2005 | 12:04 PM
ckerch's Avatar
ckerch
Not in either one of my 69 verts
Old Feb 25, 2005 | 12:45 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
They weren't on mine and I'm fairly certain the front end had not been apart previously.
Old Feb 25, 2005 | 04:46 PM
cruzzin-style's Avatar
cruzzin-style
Hi: Those horseshoe shaped thinggies are actually like a dampner (sp). On the posts that say they didn't see any. They should be there. Maybe disgrinated? Actually, IMHO, I don't think they're needed.
Old Feb 25, 2005 | 04:53 PM
Twin_Turbo's Avatar
Twin_Turbo
Those coil spacers are not stock. They are a cheap solution to sagging springs.
Old Feb 25, 2005 | 06:12 PM
NHvette's Avatar
NHvette
I agree - taken apart (2) 70s and (1) 75 - no spacer/damper - whatever.
Also, be sure when putting the new springs in that the
coil end lines up in the UPPER pocket ... bottom is not important.
Old Feb 25, 2005 | 08:04 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
While at a corvette show i saw some spring spacers becasue i was lookign some for my 66 becuase i cant find a spring with the right height. The spacer where in a nos gm box and the guy said they came factory on i think 71 bb's.
Old Feb 26, 2005 | 02:28 AM
TXShark's Avatar
TXShark
Thanks for the inputs. My clue should have been they were metal. I'll pull them out as soon as I get back to town. I was careful about aligning the springs in the upper pocket. It does drive much better with the new front end, corners like, well, a Corvette. Guess I should have looked more closely at the pictures....
Old Feb 26, 2005 | 03:39 AM
djcwardog's Avatar
djcwardog
My 1973 did not have them either when I rebuilt the suspension. From reading here I think you need to carefully check how the bottom of the spring gets oriented when you reassemble. As I recall, there is a hole drilled in the LCA that you want at least 1/2 exposed, so the bottom end of the coil must be aligned with that hole - and it will move a little as you raise up the LCA to reassemble the spindle and UCA... I don't remember that there was a concern about spring alignment in the UPPER control arm (UCA)... Have I missed something? After I get home this summer, I'll be pulling mine apart to install offset pieces in the UCAs...
To Suspension question
