Looking for opinions and suggestions...
Utilizing my stock 454 Motor. Factory Heads, Factory intake.
Do I clean up the old factory 4 barrel or is there a Holley, ect available that will bring this BB back to life. Upgraded the Dist. to MSD w/Tach drive. Sanderson Headers. and a mild Comp cam upgrade.
Assuming an LS5, your stock intake is for a Qjet so your best option is probably the carb already on it. You didn't provide much info on the cam other than "mild" and based on that I doubt that you'd see much benefit from more carb. If you're looking to "bring it back to life" your first step should be to find out why it died and fix that.
