Problem with my '70 headlights
Old Feb 25, 2005 | 10:50 PM
ismaelg's Avatar
ismaelg
Default Problem with my '70 headlights
Hello,
I'm having some electrical gremling on my '70. I'm replacing the lamps. I put 2 new halogen lamps in the driver's side. Still need to fight the passenger side. In the bright mode both lamps turn on, but in low beam, they both go off. Since the low beam has 3 prongs, I assume there are 2 elements, one for low beam and one for high beam. What voltage should I see in the low beam lamp connectors? Could this be related to the dimmer switch? Any guidance will be appreciated. By the way, I almost had to take the whole front of the car apart to remove the bezel so I could take the lamps out.
Thanks,
Ismael
Old Feb 26, 2005 | 11:53 AM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
Power for your low beams comes from the TAN lead to the left headlamp. The right headlamp gets the power from the left side via a TAN wire.
Your dimmer switch is fed by the LIGHT BLUE wire fri=om the light switch. From the dimmer switch, TAN is for the low beams and the LIGHT GREEN is for the high beams.
So you should have 12 volts at the dimmer switch and at both leads coming from it. Start there. If you have power there go to the lighting harness connector on the firewall, the left connector. Check for power there. If it is there then trace the TAN wire to the left lamp. If it isn't there, the TAN wire is broken somewhere.
If you had a wiring diagram, it would help you.
Don
Old Feb 26, 2005 | 12:18 PM
70blueshark's Avatar
70blueshark
Thanks,
Ismael
Going through the same thing with my 70 right now. I'm on day 4 of soaking the old screws in WD-40 just to try to get the reatining ring and mounting ring off the old lamp!
I'm starting to consider spending the $100 or so bucks to just buy new all rings and screws.
Let us know how you make out.
Dave
Old Feb 26, 2005 | 01:08 PM
ismaelg's Avatar
ismaelg
Don,
Thanks for the info. I replaced all 4 lamps and the passenger side work fine. That means the problem is only on the driver's side, after the junction that feeds the other side. As for taking the bezels out, I ended up removing the housing actuator screw (3/4" bolt) and loosing up the 2 screws on the side that hold the stop bolt so I could lift the whole thing hi enough for the bezels to come out.
Thanks,
Ismael
Old Feb 27, 2005 | 03:22 PM
70blueshark
Ismeal,
I just put the new lamps into my 70 and experienced the same exact problem that you are discribing. My wife, who has an engineering degree, suggested that there might be a problem with the contacts and it could be disrupting the ground.
Sure enough I went back, pulled out the lamps, cleaned and aligned the contacts, and now everyting works fine.
If you have not done so already I suggest you try this before you go pulling things apart chasing wires.
Good luck.
Dave
To Problem with my '70 headlights
