Opinion - BB Head Experts
Old Feb 26, 2005 | 06:36 PM
Hvymtlc5's Avatar
Hvymtlc5
Default Opinion - BB Head Experts
I have a set of nice oval port (702) 427 heads. They are completely reworked and ready to go back on the car. Here's where I need some help or a sanity check...My valves are currently 2.06 / 1.72. Desk top Dyno shows that with my particular engine build (cam, headers, carb, etc.) I will gain about 25 - 35 HP by having bigger valves (2.19 / 1.88) installed.
Is it worth doing? Machine shop work and new valves will cost about $350.00. The machine shop guy says - don't bother. I think there is a pretty significant gain in flow and subsequent HP.
Would you spend the money?
Old Feb 26, 2005 | 06:46 PM
Corey_68's Avatar
Corey_68
That's a tough call. Though for what it's worth I know guys w/ 350's that have bigger valves than you have. Personally I wouldn't bother, I'd take that money and put it towards a new set of performance heads. In the meantime enjoy the vette.
Old Feb 26, 2005 | 10:10 PM
Les's Avatar
Les
It IS a tough call. I can only speak for myself- if I had no plans to get new heads I'd have the bigger valves installed. I always look for a way to max out my combo because I don't like having to wonder how much better it could have run. Those valves will make a difference especially if you have an aggressive cam, good intake set up, & good exhaust. If you don't feel like spending the $350 then just forget about it & don't look back.
Old Feb 26, 2005 | 10:37 PM
MrForce's Avatar
MrForce
St. Jude Donor '11, '14
It is a tough call but $10 per horsepower is cheap. It will also help with all the other mods you do. Oval ports with big valves is basically what GM and Edelbrock are pushing.
Old Feb 27, 2005 | 08:49 AM
Hvymtlc5's Avatar
Hvymtlc5
I tend to lean toward getting the larger valves installed -- so I don't keep trying to second guess myself. All the flow charts show bigger improvements.....If I didn't plan on trying to run a more radical cam, I could probably get by with less flow. I guess $350.00 for 20 or 30 HP isn't such a bad deal. Wish I would have done this when I first had the hweads reworked ,,,,,,,
To Opinion - BB Head Experts
