Hooker side mounts.
Old Feb 28, 2005 | 05:52 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Hooker side mounts.
On the side tubes, can the exhaust dump out be turned more toward the ground or is the position "fixed?" Seems like they'd be easier on the ears than the side position.
Old Feb 28, 2005 | 05:54 AM
1979toy's Avatar
1979toy
To turn the outlets down would require cutting the brackets off and welding new brackets on.
Old Feb 28, 2005 | 08:46 AM
Edzred72's Avatar
Edzred72
You'd probably have to re-chrome them cause the cut weld would show on top.
Eddie
Old Feb 28, 2005 | 11:56 AM
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
St. Jude Donor '09-'11
The first time I fitted my sidepipes the exhaust dump was straight out the side and everything lined up properly, except that the pipes were sitting too high on the car to allow the door to be opened.
I ended up bending the two mounting tabs outward a little with a rubber mallet
This created clearance for the doors and also had the added effect of turning the exhaust outlet downwards a little (probably about 10-15 degrees).
It took a bit of trial and error but the mounting tabs were fairly easy to bend and it had no effect on the jet hot coating, not sure what will happen with chrome though.
To Hooker side mounts.
