Welding aluminized pipe
Old Feb 28, 2005 | 07:13 AM
70_Shark's Avatar
70_Shark
Default Welding aluminized pipe
I'm getting ready to weld my exhaust and was wondering if the aluminized pipe gives off any dangerous gases like galvanized metal?
Just trying to stay out of trouble. Thanks.
Old Feb 28, 2005 | 07:34 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Use a sandpaper wheel or wirebrush-wheel to remove the aluminum from the weld area.
It's not only the weld quality (splatter) - it really stinks very bad and smokes when it burns off the pipe during welding ... it's not very healthy either....
Old Feb 28, 2005 | 09:16 AM
ffas23's Avatar
ffas23
To tell you the truth I never had a problem with it. I Mig Welded header collectors to aluminized pipe on my Street Rod and never noticed anything special as far as any dangerous gases. I have also welded aluminized pipe on other occasions and been around others welding it. Most all the replacement exhaust for cars is aluminized anymore and being in the parts business that I am in I have never heard of anyone complaining about any gases when going around to the repair shops over the years and I see plenty of shops now and in the past working with their Mig Welders on this aluminized exhaust. Go and get a piece of scrap aluminized pipe and do a couple of welds to it and see for yourself. I usually keep pieces around so that I could set my Mig welders heat and wire speed up before working on the project at hand.
Old Feb 28, 2005 | 09:20 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Although it may not be a problem to weld it, it will burn off anyway in that area that you weld... so why not clean it off the pipe prior to welding ?
I welded aluminized and galvanized pipe and I have to admit that sometimes I was just too lazy to get the coating off... it's not going to hurt the weld, the exhaust is going to rust anyway, no matter what you do... unless you use stainless pipes....
Old Feb 28, 2005 | 02:26 PM
stingr69's Avatar
stingr69
I have welded aluminized pipe before and never had any issues. It welds real nice. Now the galvanized steel welding gives off some bad stuff.
If you get sick from welding galvanized steel you should drink some milk. It will help you feel better.
-Mark.
Old Feb 28, 2005 | 02:41 PM
GTR1999's Avatar
GTR1999
I've welded aluminised pipe before and didn't havvvvveeee annnnnnyyyyyyyyy Prooooblleeemmmmmms
Gary
Old Feb 28, 2005 | 05:17 PM
Brown78's Avatar
Brown78
-Mark.
Got Milk!!
Old Feb 28, 2005 | 06:40 PM
joe73vette's Avatar
joe73vette
galvanizing is zinc, aluminizing is ... aluminum. it's the zinc that gets you. joe
To Welding aluminized pipe
