is this T56 big !
Old Feb 28, 2005 | 02:34 PM
WESCH's Avatar
WESCH
Default is this T56 big !
Hi
My new GM-T56 Viper tranny beside the original M21 from my 68 Vette.
What a size difference, I hope it fits into the tunnel .
Günther
Old Feb 28, 2005 | 02:37 PM
Corey_68's Avatar
Corey_68
Hope it fits too since I'll be ordering thre same tranny this Summer.
Old Feb 28, 2005 | 02:49 PM
69schemers's Avatar
69schemers
It will fit. Already done.
Old Feb 28, 2005 | 02:55 PM
70 LS1's Avatar
70 LS1
It will fit just fine. When I did my T56 install, I had to cut out the shifter opening in the tunnel so I could remove the shifter from the top.
Old Mar 1, 2005 | 10:04 AM
fontking1a's Avatar
fontking1a
I've got the same thing planned for my car. Let us know how it goes and good luck. Also, could you figure out your best MPG in sixth gear cruising a flat freeway at 65 mph. I'm hoping you come up with something over 20 MPG.
Old Mar 1, 2005 | 10:16 AM
WESCH's Avatar
WESCH
Hi
The BB should run with around 1.625 RPM at that speed, so just above idling.
I probably have to reinstall the small 650 CFM carb again.
Günther
To is this T56 big !
