What intake should i use?
Old Mar 1, 2005 | 07:35 PM
Entropy's Avatar
Entropy
St. Jude Donor '08-'09
Default What intake should i use?
I'm trying to decide if I should use an Edelbrock RPM or a Weiand stealth on my 72 rebuild.
Here are some basic numbers for the comparison
9.5:1 CR
280 duration comp cam
993 heads with 2.02 intake/1.6 exhaust valves
I plan on using the stock quadrajet for now, plan on upgrading to a demon with mechanical secondaries later.
Also using original exhaust manifolds for the moment until I can save up a little more cash for some nice hooker super comp long tube headers.
so what do you all think?
trw
Old Mar 1, 2005 | 07:52 PM
den(thevetteman)78's Avatar
den(thevetteman)78
I might be off the track but i think the edelbrock rpm dont fit under a stock vette hood. Only the performer will fit.
StickShiftCorvette's Avatar
StickShiftCorvette
I'd use a Torker II with your setup. If you had more compression and cam I'd opt for a Victor Jr. I have run single plane manifolds since 1977 and over 140,000 miles.
Old Mar 1, 2005 | 08:02 PM
john1977's Avatar
john1977
How do you guys get your hoods closed,about the only thing i could use with my stk L48 hood was the performer intake,then its even close.
Old Mar 1, 2005 | 08:06 PM
page62's Avatar
page62
Drop-base air cleaner.
Old Mar 2, 2005 | 11:26 AM
Entropy's Avatar
Entropy
What kind of drop base air cleaner should i go with?
Any suggestions?
Does anyone have the edelbrock rpm with a quadrajet and a dropbase that actually is below the stock hood?
Thanks for the suggestions.
trw
Old Mar 2, 2005 | 11:31 AM
AGVI's Avatar
AGVI
Canadian Events Coordinator
I have the performer RPM and my hood is lower than earlier years.
Old Mar 2, 2005 | 11:34 AM
Entropy's Avatar
Entropy
AGVI,
What carb are you running?
Did you use an adapter plate?
trw
Old Mar 2, 2005 | 11:47 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Any suggestions?
trw
LOSTPATROLMAN, mike set me up with a MOROSO drop base air cleaner that was sweet......
Old Mar 2, 2005 | 11:58 AM
C3Muscle352's Avatar
C3Muscle352
if you put the L-86 or whatever hood on would that work too because i was conteplating an edelbrock rpm also in my '78 with an edelbrock 650 somethin carb [ havnt decided yet] but i seriously thing it wont fit. i was also thinking about just having a custom hood made to get ram air flowin so that i wont lost hp from having a smaller intake am i correct about that?
Old Mar 2, 2005 | 01:33 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
trw
If you are going to use a quadrajet you will have to use a performer or Weiand with a spread bore type mounting flange or use an adapter which will add an additional inch or more...
Old Mar 2, 2005 | 01:40 PM
Entropy's Avatar
Entropy
hey yellow 72.
The edelbrock 7104 is set up with the spread bore bolt pattern...I guess I'd like to know if I use that intake, with my original Q-jet carb will the original dual snorkle air cleaner I have still fit underneath the hood? I really like that air cleaner, it looks sharp and the chrome on it seems a lot nicer then the stuff in stores today. Do you have any (or does anybody else for that matter) experience with this type of set up?
I do have the stock L-48 hood.
thanks,
trw
To What intake should i use?
