Probably need new engine...
Old Mar 2, 2005 | 10:50 PM
Nascar5085's Avatar
Nascar5085
St. Jude Donor '06
I got the same problem with no place to work on the car and I got a quote of 2500.00 to rebuild my engine.
Old Mar 2, 2005 | 10:58 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
Get some good aftermarket heads and a new cam for under $1000. Get some friends and you will fit it all in a weekend.
IF you want bang for buck AND want to drive it to work then keep the original configuration so that you can pass smog tests. I don't know how good flowing heads effects smog tests, might need to check that, a CAM probably will.
Old Mar 2, 2005 | 11:03 PM
raydog9379's Avatar
raydog9379
Why do they have to rip us off just because its a Vette??? I wonder if the same 350 was in a beat up pickup truck if you'd get quoted the same.. Someone should check it out to see..
Old Mar 3, 2005 | 07:34 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Edelbrock is one of the companies that claim their heads/cams are emission legal - they're not the cheapest, heads and cam plus pushrods will be about $1300, then add a carb and you're looking at roundabout $1700 with all the new gaskets and small stuff you need.... and yes, it can be done on a weekend... and the engine will run great after the "repair"
Old Mar 3, 2005 | 02:15 PM
Kalway's Avatar
Kalway
Well we found out it has a flat spot in the cam after all. The exhaust valve wasn't even lifting.
Suggestions on where to go from here? Just put a new cam in, new block, other suggestions?
Old Mar 3, 2005 | 02:24 PM
djcwardog's Avatar
djcwardog
You found this out after trying to adjust the lifters with the engine running at a low idle speed? Loosen nut until you hear that rocker rattle, tighten nut until rattle goes away. Tighten nut another 1/2 turn... The rocker nut gets turned slowly always! You also should check to be sure that the pushrod is OK - i.e. straight and proper length (worse case - not missing an end down in your block...). If still no lift on that valve then you likely have found the answer - new cam and lifters inbound! Since you are on a budget, get a hydraulic flat tappet cam like what came in your car. You will likely want to stick with your stock valve springs for now, so don't go wild on the lift. 0.500" or thereabouts at the valve is the idea, forget about 0.600" and higher! Be sure the cam you pick is rated to work with the stock valvetrain. Basic idea for choosing a cam: For the street, high lift, short duration will feel good when you punch it. For racing, longer durations give you better power at higher RPM's...
Old Mar 3, 2005 | 02:59 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Why would you think about a new block if it's only the cam ? IF it is only the cam, remove the intake, remove the lifters (note which lifter was where) and inspect the cam lobes through the lifter holes... shine a flashlight in there to inspect the cam lobe surfaces...
I got the edelbrock Performer cam from AutoZone or AdvancedAutoParts... $140 including the lifters - smog legal and the engine runs great with it...
At this time you also want to inspect the pushrods and rocker arms and replace as needed...these are not expensive so you may want to replace them just to be sure you don't have to go back two weeks later to do it...
I never removed/installed cam bearings, hopefully some members can give you advice on these....
At the beginning of this thread you were thinking about a new engine, now you're down to a $300 repair... isn't this forum great ???
Old Mar 3, 2005 | 03:03 PM
markdtn's Avatar
markdtn
Just put a cam and lifters in it. Even at repair shop rates it should be less than $1000 and should only take a day or 2 for them.
Old Mar 3, 2005 | 03:05 PM
thebruce's Avatar
thebruce
As for your cam question, no, the engine does not to be pulled. Plenty of info in Tech Tips here and on corvettefaq.com to show you how. I've done it twice now, and you don't need to me a master mechanic to do it yourself.
Old Mar 3, 2005 | 07:01 PM
Kalway's Avatar
Kalway
Well the vette is still in the shop and the shop said it was a flat spot on the cam. I'll check out a cam and lifters.
Old Mar 3, 2005 | 08:01 PM
thebruce's Avatar
thebruce
I'm sure most people here will tell you that if you wiped a cam lobe, you will need to tear the engine down because of all the damage the loose metal will do to bearing surfaces, etc. Kind of hard to argue with that.
AT A MINIMUM you MUST get the entire engine flushed. Many shops have engine flush systems that run a cleaning fluid through the engine, and this will remove pretty much all of the metal particles that were once your cam lobe. Some cleaning solutions are oil based, some are water based. Try to go somewhere that they use an oil based solution. Keep in mind that if you just have it flushed, you're stuck with whatever damage the metal particles did before you caught the problem.
For the record, I had the exact same thing happen to me (#8 exhaust lobe wiped). I had the engine flushed, because there is a 406 buildup in my car's future, and I wanted to keep this one running for the time being.
Good luck!
Old Mar 4, 2005 | 09:49 AM
Kalway's Avatar
Kalway
I was just thinking about what the hell might have happened to the metal on the cam, to flatten it out. I did do a motor oil flush like 2000 miles ago but that probably didn't flush out any metal from the cam. I have to wait to find out if the shop can get the one lifter out, because it might be stuck. If the lifter is stuck I think I'm going to look in to a new block, just to save myself some time. If it comes out I'm looking at the edelbrock performer plus camshaft kit.
Here's a good question, will the L-82 or LT1 (1970-71) cam and lifters work on the L-81, without needing other replacements?
Old Mar 4, 2005 | 09:52 AM
  #33
page62's Avatar
page62
The L82 cam will work just fine. The LT-1 cam used solid lifters...I don't think you want to go there...
Old Mar 4, 2005 | 10:00 AM
  #34
Kalway's Avatar
Kalway
So should I go with a GM L-82 and L-46 replacement cam PN# 3896962
Or the edelbrock performer plus from like pep boys or autozone?
I'm geussing the LT-1 cam and lifters would require something else to be changed to work correctly?
Edit: I looked at the LT-1's specs and see it needs a lot more power from the intake to accompany the cam.
Old Mar 4, 2005 | 01:11 PM
  #35
Kalway's Avatar
Kalway
After speaking with my cam expert friend I went with a cam from Summit Racing.
SUM-K1103 Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 272/282, Lift .442/.465
For the price of a regular GM cam I have that kit shipped to the shop tomorrow (Saturday). Input?
Old Mar 4, 2005 | 01:12 PM
  #36
page62's Avatar
page62
Help me out here (I'm not certain), but isn't that a loooooong duration cam??? (Lift is good, though.)
Old Mar 4, 2005 | 01:17 PM
  #37
Kalway's Avatar
Kalway
That's the advetised duration.
Duration at 050 inch Lift: 214 int./224 exh.
Shorter on the intake and longer on the exhaust than the L-46/L-82 cam.
To Probably need new engine...
Old Mar 4, 2005 | 01:24 PM
  #38
page62's Avatar
page62
Ahhh...okay. I knew something seemed a little off. I'm no expert, but I think that's a good cam for the L81
Old Mar 4, 2005 | 02:38 PM
  #39
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
That's a little more duration than the Performer plus and a lot less than the Performer RPM (Ihad both cams from edelbrock)... yours should run fine, the RPM cam is too much for a low compression engine.
Old Mar 4, 2005 | 04:00 PM
  #40
johnnybrewmeister's Avatar
johnnybrewmeister
Talking to the DMV won't be sufficient. You need to go to their webpage and print out the section of whatever doc specifically states this. Then take this with you when the next DMV bozo doesn't believe you (had this happen when I first registerd my '73).
Are you truly only going to drive this to shows/events? This would seem like an easy thing for revenue-hungry SD cops to target.
Be careful.
