Changing my ignition lock...?
Old Mar 2, 2005 | 10:34 PM
Toyvet's Avatar
Toyvet
Default Changing my ignition lock...?
MY '69 standard column igniton lock thumb tabs have been broken off.
What is the procedure in changing the lock tumbler with thumb tabs intact ? Source for the new parts needed for NCRS judging ? Thank you
Old Mar 2, 2005 | 11:07 PM
Jim Shea's Avatar
Jim Shea
Changing the lock cylinder is quite easy. Lock cylinders are readily available from GM dealers as well as various Corvette suppliers. I am not sure what makes one NCRS correct however.
The lock cylinder is the same regardless if you have a T&T column or a standard (non-adjustable) steering column. There are slight differences between a T&T column and the standard column in terms of the actual repair procedure. I have for both type columns posted at www.corvettefaq.com and they are identified as Disassembly & Repair Paper #1 and Disassembly & Repair Pic #1.
If you have any problems, just continue posting.
