68-72 temp guage check
Old Mar 4, 2005 | 10:12 AM
MELVINJ's Avatar
MELVINJ
Default 68-72 temp guage check
How can I test my temp guage to see if its the sensor in the block, or or gauge itself
Old Mar 4, 2005 | 11:22 AM
GDaina's Avatar
GDaina
John, if the temp gague isn't working, check the wiring and the connection to the gague.
Old Mar 4, 2005 | 11:37 AM
62fuelie's Avatar
62fuelie
With the ignition on, MOMENTARILY ground the sensor wire. The gauge should read full scale. If the gauge reads, but is inaccurate, it's probably a sender issue. Check gauge reading against an IR gun to be sure if gauge reading is faulty.
Old Mar 7, 2005 | 10:08 AM
BeaterShark's Avatar
BeaterShark
If you want to test your gauge, you can do it with a resistor. Get a 100 ohm resister (Radio Shack). Connect one end to the temp sensor wire and the other end to ground. Your gauge should read about 210 or so.
I took my sending unit and measured it's resistance in heated water in a pot on my stove. Here are the values I found:
Temp----Sensor
155------185ohms
190------134ohms
205------109ohms
Old Mar 7, 2005 | 11:59 AM
Tom454's Avatar
Tom454
J...
I was just there... 401, 401 bypass.... up 87. Was looking for your car... didn't see it.
Actually... I was looking for (to buy) a backhoe.... RSC on 87.
Old Mar 7, 2005 | 12:35 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
I replaced the needle on my 69 gauge and forgot where it needs to be set with the gauge out of the car. Any help to jog my menory is appreciated.
To 68-72 temp guage check
