Removing adhesive from plastic
Old Mar 4, 2005 | 05:31 PM
Older Than Dirt's Avatar
Older Than Dirt
Default Removing adhesive from plastic
Anyone know what will remove the old adhesive from the seat backs and kick panels where the carpet pieces were affixed? I'm going to paint my seat buckets and kick panels and then install new carpet pieces. I think the 79-82's were like this. The problem is finding something that won't attack the plastic parts.
Old Mar 4, 2005 | 05:46 PM
moosie982's Avatar
moosie982
Hey, Try some WD-40, it works on most glues,,, Good Luck,Peace,,,Moosie
Old Mar 4, 2005 | 05:56 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I've used stuff called "Goof-off" and a spray by 3M...can't remember the name though.
Try it on a test area first....maybe the back of a panel.
Old Mar 4, 2005 | 06:27 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
Or rubbing alcohol. that stuff does a good job on most glues.
Old Mar 4, 2005 | 06:34 PM
72GACRZR's Avatar
72GACRZR
WD-40 and you can try lighter fluid if you don't want the oil mess. Test an area first for the lighter fluid, I use it for removing price stickers on packages. Firat saw it used at Goodwill to remove old stickers from book jackets and paperbacks.
Old Mar 4, 2005 | 07:15 PM
Ex_F-Body_Enthusiast's Avatar
3M Adhesive Remover or Goo Gone usually does the trick.
Old Mar 4, 2005 | 07:16 PM
Toms82's Avatar
Toms82
Default removing adhesive
Hi,
I did the same job on my 82. I don't remember that there was too much glue residue on the plastic kick panels and seat shells. I scraped off the excess old glue, re-sprayed the plastic parts and then glued the new carpet parts on. Eveything held on very well and that was a few years ago. When using the 3M spray adhesive make sure you have alot of ventilation, that stuff is nasty!
Good luck,
Tom
Old Mar 4, 2005 | 09:43 PM
Older Than Dirt
Thanks for the ideas guys. I tried lighter fluid and alcohol and neither worked. The wd40 worked better but I'm concerned about cleaning the residue off that it leaves.I might have problems in the areas that I want to paint. Think I'll try the 3M stuff tomorrow and do some scraping.
Old Mar 4, 2005 | 10:25 PM
ram82fire's Avatar
ram82fire
GOOGONE ,,,,,,,,,,,,,,,,, will not hurt paint or plastics it's da bomb
Geo
Old Mar 4, 2005 | 10:29 PM
Older Than Dirt
Do auto parts stores sell GOOGONE?
Old Mar 4, 2005 | 10:44 PM
I haven't seen Goo Gone in Auto Parts stores, but I picked up mine at Home Depot; even Wally World might carry it. . .
Old Mar 6, 2005 | 10:37 PM
mooneyd's Avatar
mooneyd
Geo
This works!
Old Mar 7, 2005 | 01:29 AM
codestar7's Avatar
codestar7
Default Remove the gooo
Denatured Alchohol and elbow grease, Does it every time!
Old Mar 7, 2005 | 11:19 PM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
I've never tried it before, but someone told me to use a heat gun the next time instead of chemicals.
Old Mar 8, 2005 | 12:48 AM
Older Than Dirt
I picked up some googone at HD today.........it works pretty good!
To Removing adhesive from plastic
