Stalling in gear
Old Mar 4, 2005 | 07:57 PM
twistdpair's Avatar
twistdpair
Default Stalling in gear
My 78 seems to be prone to stalling when I put her in gear, either forward or reverse. The idle is a little high in neutral, aroung 1200. Then when I pop it into reverse or drive, it may stall. In addition, it will sometimes sound like it's going to stall when coming to a stop while driving. It almost seems like the torque converter is sticky or something and not disengaging.
Any ideas?
Thanks for the help.
Corky
Old Mar 4, 2005 | 09:58 PM
73'Vette's Avatar
73'Vette
Did you make any changes, or is this a new problem that happened all of a sudden?
Old Mar 4, 2005 | 11:00 PM
twistdpair's Avatar
twistdpair
I just bought the car last week.
-Corky
Old Mar 4, 2005 | 11:08 PM
vette rod's Avatar
vette rod
Sounds like the converter is to tight. Possible vaccum problem also.
Old Mar 5, 2005 | 12:54 PM
twistdpair's Avatar
twistdpair
Can the converter be loosened? Is it possible that maybe it's a replacement "heavy duty" type converter with less slip? In the meantime, I'll check the vacuum lines and see if there's anything obvious.
Thanks for the help!
-Corky
Old Mar 5, 2005 | 01:03 PM
vette rod's Avatar
vette rod
yes it can be loosened and put a vaccum gauge on the engine check it in gear wih brakes applied (power brakes use up the vaccum )
To Stalling in gear
