Engine swap
Old Mar 4, 2005 | 08:04 PM
twistdpair's Avatar
twistdpair
Default Engine swap
I don't know if it's a little tired, or if the power/weight ratio of the L-48 in a big vette sucks, but I decided to put another engine in my 1978. I will still hang onto the original L-48 because I know when I sell someday, someone might care about original equipment. I have a friend with a rebuilt 350 (with performance cam, intake, heads, etc.) that cranks out about 290 HP and has 1500 miles on it. He just bought a house and said he'd give me the engine for $200.
Anyhow, to the question: Can I slap any 350 SB into my 78 and expect the A/T bell housing and everything else to match up?
Thanks for your help!
-Corky
Old Mar 4, 2005 | 08:39 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
-Corky
yeah probably....if its a small block chevy?....the motor mounts should line up, the heads may or may not have accesory holes...look for them these are the holes the alt bracket etc. attach to....the flex plate may or may not be the same depends if its a one piece or two piece rear main seal, the bell housing bolts should line up, Can't think of any other issues....
Old Mar 4, 2005 | 10:42 PM
johnt365's Avatar
johnt365
Yes.
That is why we drive Chevys
you can get alot of info from http://www.chevymania.com and click on parts id. this will tell you from the casting #'s what you have and what it was used for.
Old Mar 4, 2005 | 10:54 PM
twistdpair's Avatar
twistdpair
Cool! Thanks a lot guys, I'm picking up the engine this weekend. I was shopping for crate engines, and I can't pass up this deal...
Wish me luck w/ the swap...
-Corky
Old Mar 4, 2005 | 11:57 PM
Mike Mercury's Avatar
Mike Mercury
$200 ????
Damn; that's a nice friend you have
Old Mar 5, 2005 | 02:41 AM
Corvus's Avatar
Corvus
$200? that's a steal. By the way good move keeping the original L-48 it may become valuable...some..day. andy ou should have no issues at all Good luck, and make sure you give us PICSSSSSSS
Old Mar 5, 2005 | 07:02 PM
marshrat99's Avatar
marshrat99
I slapped a 350 4 bolt block out of a 85 Suburban into my 79. I didn't use anything else, just the block. I used Dart heads, the original motor mounts and flex plate.
Old Mar 5, 2005 | 07:44 PM
twistdpair's Avatar
twistdpair
I'll post some pics when I do it. I don't know if I'll do it this year, as there are only a few suitable Vette months in Connecticut and it IS running now...I might wait until this fall/winter but I wanted to snap up the motor anyhow.
-Corky
To Engine swap
