Garage pics please
Old Mar 7, 2005 | 11:50 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Originally Posted by gliot1
[IMG]xxxxxxxxxxxxxxxxxxxxxx.JPG[/IMG]
(1400x1240)
My god man resize!!!!
Old Mar 8, 2005 | 12:00 AM
74FLCONV's Avatar
74FLCONV
Originally Posted by Cali,68,L-79
(1400x1240)
Look who's talking! I remember when you used to post pics so big, I had to go out and buy a bigger monitor!
D. Ocean
Miami, FLA
Old Mar 8, 2005 | 12:01 AM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
That must be one of them TEXAS Panoramic type of pics lol. Rare pic indeed but I did not see one Jackolope
Old Mar 8, 2005 | 07:36 AM
igo4vols's Avatar
igo4vols
Will get the number and answer the other questions when I get home this afternoon.
Old Mar 8, 2005 | 08:16 AM
brooksman9's Avatar
brooksman9
St. Jude Contributor
Originally Posted by igo4vols
I called Armstrong before I did it. Here is what they told me:
- Thoroghly clean the floor (etching is not required)
- Use the peel 'n' stick tile (other adhesives have issues with auto fluids)
- Once complete, wax with a commercial floor wax
- Let set for 3 days (curing prevents hot tire marks)
- Done
I followed their instructions and now can clean the floor with a swifter mop and the cars no longer get dusty and it looks cool. I used the black and white checkered pattern but you can get them in almost any color combination. Home Depot has a catalog. By the way, 800 sf cost me around $150.00.
I would think that the "peel n stick" tiles would come up easier if you turned the wheels or something like that. Have you had any trouble in that area?
Old Mar 8, 2005 | 09:53 AM
Scooter70's Avatar
Scooter70
Here's my dad's garage. (Here's the thread from a few weeks ago about it.)
Old Mar 8, 2005 | 10:08 AM
RATT7's Avatar
RATT7
Here it is
Old Mar 9, 2005 | 08:55 AM
igo4vols's Avatar
igo4vols
Floor answers
- Model number. Learn something everyday. The box says Armstrong 25222-011 but I couldn’t find it on their web page.
I called Home Depot and said that I actually have Newport 210-72.
Pattern: Candy Square. Which was sold by Armstrong. I searched the web and found this:
http://www.metroflorusa.com/products/classic.html . I got lost on their website.
- Installed it Sep 3, 2003
- Floor jack is not a problem. I do use pieces of plywood for the jackstands though.
- It is holding up very well. I have replaced just one tile and that was because I dropped a utility knife from about 8 ft
and it landed blade down. It gouged the tile but was barely
noticeable. It bugged me so I cut the tile out and put a new
one in.
- My floor was about two years old and had been previously
painted. I didn’t like the paint because it didn’t like brake fluid.
Once is started chipping I spent about 4 hours with the power
washer and removed most of it. I put the tiles right over the top
of the remaining paint.
- I have not had a problem with turning the wheels. I even
squeezed 4 cars in at one time and no problem at all. Occasionally
I bring my tractor in for maintenance and it has knobby tires – still
no problem.
Old Mar 9, 2005 | 09:20 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Originally Posted by Jclgodale3
Very nice garage, but what's up with the sock?
Old Mar 9, 2005 | 11:13 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
Originally Posted by vince clortho
igo4vols- I am really interested in the Armstrond tile as well. Let us know what the exact description or item # is.
gliot1- Your floor looks like mine used to. Is that the Rustoleum epoxy? I have painted mine twice with it. I acid etched, used TSB substitute, and even belt sanded the concrete. The paint has peeled up both times over the last two winters. I think the road salt may be doing it, but hot tires also lift some. How has yours held up? Did you apply it to new concrete or old? What prep work did you do?
This is not the standard water based epoxy you buy at Home Depot. It is an industrail solvent based product, whcih can be ordered from any supplier. I worked with a Rsut Oleum engineer from my Vette club, whos tells me this is the product to use. Water based stuff just doesn't quite hold up, but due to EPA regulations it's what they are driven to. I am in Chicago and I have no signs of hot tire pull or any winter damage. It cleans supurbly and it is the best paint I have used over the last 10yrs. It is what they use in most car dealer service bays. I cold barely cut through this stuff with a carpet knife along the taped baseboard. I am very please with the results.
Old Mar 9, 2005 | 11:20 AM
gliot1's Avatar
gliot1
Old Mar 9, 2005 | 11:49 AM
Patrick73's Avatar
Patrick73
Ronald (gliot1): Can you provide any more information re the industrial product? Name, manufacturer, product number, etc? Can it be obtained at any local paint store (not Lowes, Home Depot, etc.), but a Sherwin Williams/Kelly Moore type store?
Old Mar 9, 2005 | 03:16 PM
  #33
MIKER's Avatar
MIKER
Thanks for the info igo.
Floor answers . . .
Old Mar 9, 2005 | 04:25 PM
  #34
gliot1's Avatar
gliot1
It can be obtained at any place that sells the water based product, by order. It is RustOleum, (don't have numbers handy) two part industrial. My floor is around 660sq. ft. and it would cost around $350. Make sure it is prepped properly; no oil, grease, old paint etc. I used a diamond wheel grinder to get all of the old paint off and thouroughly cleaned the floor befoer painting. You will need two coats and it has to dry 3-5 days in between. It only took a few hours to do my floor each time. It was much easier to work with than I thought, but I would suggest that you throw out any rollers, brushes,etc. Cleaning them is a waste of time.
Old Mar 10, 2005 | 07:02 PM
  #35
Patrick73's Avatar
Patrick73
gliot1: I went to the Rustoleum industrial web page. Appears you may have used either AS6500 or AS9100. Both are heavy duty epoxy floor coatings for heavy vehicles and equipment. Both are "two component products". Not sure of the difference between them. I will call Rustoleum to determine which they recommend. Let me know if you locate your empty gallon paint can--the product number should be on it. Thanks!
Old Mar 10, 2005 | 07:54 PM
  #36
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by Lotus76
This is what I want to do to my front wall in my garage also. That looks great. I have had this idea in my head for a long time now, just never have gotten around to it.
So many nice garages in this thread it is amazing. I worked out in the garage today and I cussed more about the mess than anything. Time for a garage sale soon.
Old Mar 10, 2005 | 11:54 PM
  #37
matchframe's Avatar
matchframe
Here is my garage. I painted the floor with white 2 part epoxy, then taped off 24 inch squares, then painted black 2 part epoxy. The paint is very durable, and shows little wear for constant working on the Vette. The only thing I would do different is I would coat the final coat with epoxy clear to harden it even more.
www.bigdogvettes.com
To Garage pics please
Old Mar 11, 2005 | 12:25 AM
  #38
vttedrm's Avatar
vttedrm
[IMG][/IMG]
Old Mar 11, 2005 | 12:43 AM
  #39
Jclgodale3's Avatar
Jclgodale3
sock??? you lost me here...
Old Mar 11, 2005 | 12:46 AM
  #40
Jclgodale3's Avatar
Jclgodale3
Originally Posted by vttedrm
[IMG][/IMG]
ya know? if you move some of them pics, you could store some tools to work with!!!
