17" X 9.5" Wheels
Old 03-06-2005, 06:03 PM
LS-5 71
LS-5 71's Avatar
Default 17" X 9.5" Wheels
Has anyone had success use a 17" X 9.5" rear wheel with 4 3/4 or 4 1/2 inch backspacing? Looks like it would clear. Opinions?
Old 03-06-2005, 06:20 PM
jorez
jorez's Avatar
St. Jude Donor '05
Default 17x9.5, 4 3/4 bs boyd coddingtons
i cant get the pic to show
Old 03-06-2005, 06:21 PM
jorez
jorez's Avatar
St. Jude Donor '05
http://www.cardomain.com/member_page...page_id=435875
Old 03-06-2005, 06:25 PM
68 Yellow 468
68 Yellow 468's Avatar
Hello,
I just ordered 17 X 9.5 w/ 5.5 inches of backspacing. I had to order offset trailing arms and VBP's dual mount setup (roll bar delete), and will get it installed when it arrives, but fitment should be good.
Otherwise, I had only about 3/4 of an inch on the inside of the wheel until I hit the rear leaf. That being said, 17 X 9.5 w/ 4.75 of backspacing on my current setup would have cleared.
B.
Old 03-06-2005, 06:29 PM
LS-5 71
LS-5 71's Avatar
Looks good! Do you have offset trailing arms? or did you use any spacers?
Old 03-06-2005, 06:32 PM
lvrpool32
lvrpool32's Avatar
I have 17x 9.5/285/35/17 on the back of mine with 5.5" backspacing, required offset trailing arms and a shortened rear spring from Guldstrand.
If the wheel has only 4.5" backspacing you are pushing the wheel out an extra inch plus the bulge of the tire. Would be very close to the fender and you woudl probably touch on suspension compression.
Nick
Old 03-06-2005, 06:45 PM
jorez
jorez's Avatar
St. Jude Donor '05
nope, all stock with no probs!!
To 17" X 9.5" Wheels
Quick Reply: 17" X 9.5" Wheels
