Crab - Running - Vacuum problem sloved!!
Old Mar 7, 2005 | 12:40 PM
viperjesse's Avatar
viperjesse
Default Crab - Running - Vacuum problem sloved!!
Thanks to all you guys and your valuable help with this mystery.
As stated in my previous post the culprit was the power brake booster causing a huge vacuum leak. I plugged that port and changed plugs and off it went.
I opened up the secondary butterflies about 3/16 inch and I can easily set the idle. It idles nice and lopey at 900rpm. I took a vacuum reading and have about 5 inches of vacuum.
I picked up a new 2.5 power valve to install then I'll tune and set the timing. I'll keep the vac port plugged off and install a vacuum pump and reserve tank to run my accessories.
I also bought some 78 and 80 jets to try, I believe stock on the
4777-4 Holley 650 is 76?
Any thoughts on jet size for this application?
350 .060 over, .200 domed forged pistons, Air Gap intake, Eagle heads 230cc comb chambers, 2.08 int 1.6 exh. 10:1 compression, 519/523 lift @ 297/306 duration.
Thanks again everybody.
JZ
Old Mar 7, 2005 | 12:44 PM
LFZ's Avatar
LFZ
Nice to hear you got your CRAB running right! I bet that motor sounds nice.
Old Mar 7, 2005 | 12:49 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
I thought I was the only one that caught that
Old Mar 7, 2005 | 01:11 PM
viperjesse's Avatar
viperjesse
Ah - yeah and "slove" in the title too. Brain is going faster than my fingers today. Pays to proof read.
But the crab runs great thumps and pounds at idle and screams when you hit the gas. Little bit of fine tuning yet. Can't wait to get it out on the road.
JZ
Old Mar 7, 2005 | 01:23 PM
Madmikeee's Avatar
Madmikeee
From: Sometimes I wonder... why is that frisbee getting bigger? Then it hits me.
Cruise-In X Veteran
St. Jude Donor '06
Corz's Avatar
Corz
thats one hell of a CRAB
Old Mar 7, 2005 | 01:26 PM
Madmikeee's Avatar
Madmikeee
Cruise-In X Veteran
St. Jude Donor '06
We treat our crabs right here in the Northeast
Old Mar 7, 2005 | 01:54 PM
The Dude's Avatar
The Dude
Gives a whole new meaning to, "getting sideways."
Old Mar 7, 2005 | 02:01 PM
viperjesse's Avatar
viperjesse
I'M IN FREAKIN TEARS OVER HERE MADMIKEEE!!!!!!!!!!
Holy crab I mean crap that's funny. Who blew the crab?
I'm STILL laughin!!!!!!!!!!!!!!!!
Old Mar 7, 2005 | 02:52 PM
bracketshark's Avatar
bracketshark
those are some big combustion chambers in those eagle (?) heads 230cc WTF
Old Mar 7, 2005 | 05:15 PM
EDDIEJ82's Avatar
EDDIEJ82
OK I can't resist, If anyone else is having crab problems with their vette.....might I suggest GARLIC BUTTER!!!
Old Mar 7, 2005 | 05:16 PM
Fevre's Avatar
Fevre
Originally Posted by Madmikeee
I got those from a chick in college.
To Crab - Running - Vacuum problem sloved!!
