Found these numbers on the block
Old Mar 8, 2005 | 08:19 AM
brooksman9's Avatar
brooksman9
St. Jude Contributor
Default Found these numbers on the block
It is supposed to be a Jasper rebuilt engine. Can anyone tell me what these numbers mean?
C6F450074
VO517TYZ
Both located on block just under right side front head. Thanks
Old Mar 8, 2005 | 08:34 AM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Engine stamping codes are listed here
http://www.nastyz28.com/sbchevy/spcode9.html
According to this (looking for a TYZ suffix) you have a block that was born in 1975 as a 165Hp 350 that was originally built for C-10 to 2500 trucks (1/2 ton or 3/4 ton pickup.
The top number should match the VIN number of the vehicle the engine came out of.
The V means it was built in Flint
0517 means it was built on May 17th
There should be a number cast into the block on the left side, behind the head. That casting number will tell you a little more about it (from what we already know, it will probably only add if it's a 2 bolt of 4 bolt main)
Old Mar 8, 2005 | 10:28 AM
brooksman9's Avatar
brooksman9
Thanks, I'll look for that one.
To Found these numbers on the block
