flywheel wobble
Old Mar 12, 2005 | 03:42 PM
Engraver's Avatar
Engraver
Default flywheel wobble
I'm bolting up a new centerforce flywheel to the crank. If I place an indicator on the surface of the flywheel and turn the engine over by hand, there is .006" run out. Is this going to hurt anything? How far out can it be? If I only snug the bolts up it is out .002" but when the bolts are at 60lbs it increases to .006"... so I'm thinking it is the surface on the crank that is pulling it out.
Old Mar 12, 2005 | 03:48 PM
Jclgodale3's Avatar
Jclgodale3
