Tire Shine
Old Mar 12, 2005 | 07:15 PM
redcorvette80's Avatar
redcorvette80
Default Tire Shine
I've been using Meguiar's high gloss hot shine tire spray (In a spray can) for awhile now but I want something different. This stuff comes off and leaves a black residue film on my wheels. What do you guys use? Thanks
Old Mar 12, 2005 | 07:34 PM
79VetteMike's Avatar
79VetteMike
I first clean the tires with Bleach White or bleach based bathroom cleaner. Then regardless of what I use, I spray it on and let it soak in for a few minutes. I wipe it off really well and than I apply another coat and wipe that off. I get really good results like this whether I use Armor All or Son o a Gun..
Old Mar 12, 2005 | 07:40 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
I use westleys every time i wash the car and then a coat of the tire shine... i dont have the problem you have for some reason... could it be the build up on your tires?
Old Mar 12, 2005 | 07:48 PM
redcorvette80
You know I never really thought about the buildup on the tires. I just always wiped the tires off when I washed the car. Next time I put the tire shine on I'll give the tires a good scrubdown with a brush.
Old Mar 12, 2005 | 07:54 PM
Aflac's Avatar
Aflac
St. Jude Donor '09
try using the bleach white when ya scrub them.. when I did that, the stuff that came off was poo brown and the white really came back!
Old Mar 12, 2005 | 08:04 PM
lvrpool32's Avatar
lvrpool32
Use westleys to clean with a nail brush. I then use pledge.......its none sticky and leaves a nice "satin" finish.
Nick
Old Mar 12, 2005 | 09:21 PM
78Shadz75's Avatar
78Shadz75
Default tire shine
In one word the word is "Fantastic". For 11 years now I simply spray the tires and wheels with Fantastic, let it sit only while I spray number two wheel, then with a small brush, scrub lightly (no effort hardly required)...hose it off, let it dry then two coats maximum is all that is needed of Armorall to give your tires the look yu want.
Old Mar 12, 2005 | 10:22 PM
StudDawg380's Avatar
StudDawg380
Nick
I'll second the Pledge suggestion. Leaves a nice shine and also helps keep dirt off afterwards (to an extent).
Old Mar 13, 2005 | 04:19 AM
stingr69's Avatar
stingr69
I like the Westleys to clean the rubber but it can be hard on the aluminum wheels so try to get it off quickly. The tire shine stuff I have been using lately is called "Endurance". It is purple and thick. I use a crescent shaped foam applicator. It lasts a long time and I would keep using it. When I get a chance I will try some Pledge. I have used it on the interor and it works great.
-Mark.
Old Mar 13, 2005 | 05:12 AM
qwk vette's Avatar
qwk vette
Cruising
I never use Armorall because of the alcohol agents which actually dry out the rubber.
Adams VRT is excellent.
Old Mar 13, 2005 | 09:10 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
As said above, you have to get the old tire shine off before you spray the tire. I like BlackMagig tire shine gel best - it's not a spray, it's a gel and seems to stay on the tire. It's only $5 - give it a try...
Old Mar 13, 2005 | 11:50 AM
trw's Avatar
trw
I pledge also.
Old Mar 13, 2005 | 01:32 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Dont use Armorall...it will destoy the sidewalls of the tire. use something that's made for tires!
Old Mar 13, 2005 | 01:40 PM
docmace's Avatar
docmace
6th Gear
What about aluminum rims?
To Tire Shine
