Need help, Heater Core Replacement
I have a 1970 454 W/ A/C and the core is leaking.
I understand to get the core out you can remove it through the passenger compartment, exclusively??? Please say nothing has to be removed from the engine area...(A/C)....right
Now...once the core is removed, what other things must be inspected and or purchased before reassembly. ie. foam seals Glazing Compound...ETC.
It appears that there are only 4 bolts holding the HC pleum in place to get to the HC, is this true?
I know this is not an easy job, so please help, so I only have to do it only once. I was in there once before just to change the radio.... and I'll tell you it's no fun, especially when you are 6' 2" Any little details are welcomed.
thanks
I understand to get the core out you can remove it through the passenger compartment, exclusively??? I know this is not an easy job, so please help, so I only have to do it only once. I was in there once before just to change the radio....
thanks
thanks
The toughest part of the job is removing and replacing the dash.
