poor tuning or what
Old Mar 14, 2005 | 08:10 PM
john1977's Avatar
john1977
Default poor tuning or what
Have a 77 with 350/TH350 and 355 gears,and wont spin the tires on take off. Could this just be bad tuning or what? Here is what has been done to the engine,bored 30 over,speedpro hpk102/kc1012r engine kit, cam is 214-224 at 50,443/465 lift 112 center line rated 288/298.Dart iron eagle #223100ie heads,202I/190E (not sure of cc flow). Performer intake,stock Q-jet rebuilt,headers,dual exhaust, HEI accel adjustable vaccum dist.trans has a shift kit with B&M 2400 stall conv.timing is at 12 degrees. Thae car runs fine and strong and is fast except it wont spin the tires! HELP
Old Mar 14, 2005 | 08:47 PM
page62's Avatar
page62
The high-stall torque converter will conspire to prevent wheelspin. Have you tried launching the car (you know...hold the brakes in drive and bring the rpms up to the converter's stall speed -- then release the brakes!)
Old Mar 14, 2005 | 08:55 PM
john1977's Avatar
john1977
Yes,if i brake it and bring the rpms up it will spin. Had a new stock conv. and it was so tight it was hard to put in gear without stalling the engine and it woulnt break the tires loose either. I am only running stock 225/70-15 tires,new 9 leaf spring that i thought would help and still no luck.
Old Mar 14, 2005 | 08:57 PM
lars's Avatar
lars
Your '77 probably has a 3.08 or a 3.37 rear end in it.... you'll be hard pressed to light the tires up with the stock gears, although the car should do well on the highway.
Old Mar 14, 2005 | 09:04 PM
john1977's Avatar
john1977
Had 308s,just had the rear rebuilt and changed to 355s thinking this would solve my problem,engine builder told me it was 9.5 to1 comp. and 330hp.Tried the stk conv.and the b&m 2400 with the 308s,not luck and switched to 355s.
Old Mar 14, 2005 | 09:09 PM
john1977's Avatar
john1977
By the way when it shifts from 1st to 2nd at 5500 it will barkem and jump a little side ways.
Old Mar 15, 2005 | 04:07 AM
Matt Gruber's Avatar
Matt Gruber
as the tires age they will spin.
my tires are 7 yrs old w/2/3 tread left. new thy stuck like glue, now they are dangerous.
OTOH, a stroker crank kit to 396 or even 383 would do the trick now.
To poor tuning or what
