I bought one of th "S" shaped door springs from Ecklers and it came with no install instructions. They do advise buying an install tool that looks like a bent screwdriver. I took out my broken spring, so I know which end goes on top. How the heck do I install? I tried putting the top in first but I could not get the bottom of the spring in it's hole. I pried it with a BFS but did not get much movement.
Please advise the best procedure. Is the Eckler's tool really magic?
I would get or make the special tool.....it helps. I fiddled for about 1/2 hour before really thinking it out and when I did I was done in 5 minutes. First drop the spring in the top hole. Take the tool and flex the spring back until it lines up with the bottom hole and then tap the spring up into the hole with a hammer. I hope this helps.
it was pretty easy after I figured out how line up the lower spring end, and tap it into place. BTW, I bought the spring installation tool, and I don't think I could have completed the installation without it.
A stout bent screwdriver will work, too, and is cheaper. The secret is to use the tool to pry the spring into position and then tap the bottom of the spring upward with a small hammer to set it into the hinge hole. Another tip: put a towel or some other rag in the space between the door and body so when the spring drops it doesnt' scratch the doorsill area. Good luck!
From: San Diego - Deep Within The State of CONFUSION!
Originally Posted by burners
That's pretty much what I did. A bent tool of some kind is useful. I had a few prybars that were small enough to use.
I did that too. Has anyone else noticed that the replacement Ecklers or MAD springs are a lot less stout than the OEM one? I replaced the spring on my drivers door, but the one on the other door has twice as much tension on it and holds the right side door a whole lot better.
<sorry to hijack the thread like that>
I've noticed this as well. Are the OEM ones still available? It would be interesting to compare them. Not much good comparing an old broken one with a new one.
You have to make sure that the bottom of the spring is in the lower groove or you will never get it in. Like they said put the top in first and make sure the bottom is in as well.
Don't ask me how I know this, fought that damn spring till i figured this out..
I made the tool out of a screw driver tha tI had. A little time with the torch and I bent it one way and the tip the other way so it holds onto the spring. Cost me nothing but an old screw driver that I was not using.
I too had some fustrations not having the instructions. I had my brother-in-law bend me a scredriver, found the instructions on www.madvet.com (look up c3 door spinig, download the pdf file or use the link below) and tapped that spring into place quite easily. Good luck.
Just did this job this afternoon. Took a screwdriver and put the first 2 1/2 inches in the vice. Put the torch on it for about a minute and bent it 45 degrees. Take the end of the spring with the small loop and put to the top in the notches. Used the bent screwdriver to pry sping in line with hole on bottom of hinge and tapped it up with a small hammer. This is a job I had been putting off for a while and it was a snap . Took about 10 mins , no bleeding , no cursing , not a bad task . Brent
I bought the install tool. Would have been hard to do with out it. I was in Sears awhile ago and the have some bend pry bars that should work. The tool fro Ecklers is about 9" long and bent at about a 45 degree angle about 1/2" behind the tip. I have the instruction sheet. send me your email address and I will email it to you. email: dale.r.miller@bresnan.net.
