Transplanting an ABS system...
Too late. BMW already did that, too.
lostpatrolman- It would be an interesting project. I am currently doing major mod to my '68 roadster. LS1/4L60e, suspension mods etc. Go with it and investigate the posibilities.
Dan
www.vetteworksonline.com
PEOPLE IN CARS WITH ANTILOCKS ARE AT GREATER RISK
It's an older statistic, but it was generated when half the cars came without ABS. You couldn't do the analysis as easily today. Most cars have ABS nowadays because it does help idiots steer during braking...
You're right, I overlooked the fact that all 4 wheels are controlled seperately. A proportioning valve will get you close to front/back equality on a non ABS car, but that can vary with the conditions. However, it has been shown that the same car with ABS stops marginally slower than the car with the ABS disabled can. In fact, remembering videos in my Driver's Ed class (we never had to practice parallel parking, but we watched plenty of movies!) they said that ABS does not claim to stop the car faster! ABS locks up the brakes on and off, this is Not threshhold braking.
As far as computers doing things better than people? They can add faster, near-zero reaction times, react to things they're designed to react to, modulate the brakes 1000 times per second. Can they "feel" the tires just starting to lose traction? Apparently not or ABS would threshhold brake. Another thing I remember reading, there has been little success trying to get a computer to operate a car on the race track. Far more complicated that just braking well, but serves to demonstrate the kind of thing that computers cannot do as well as humans.
I do not know of a single racer than uses ABS, maybe there are some less experienced that do? If you need the ABS to feel when you're braking too hard, you may be like the guy at work who we call "Larry who can't feel his feet."
As for the active handling stuff, anyone who reads Road and Track or any of those magazines can tell you that active handling (even on supercars) is referred to as either more or less obtrusive, but always SLOW!Driver aids are for soccer moms.
-Chris
I've got all the goodies: overdrive tranny, rack & pinion, perhaps even EFI one day. But ABS isn't anywhere on my list!
BTW: My daily driver has ABS. The wife's DD has ABS, traction control and god knows what else (it's a Mercedes). So I ain't blowing smoke here...
Drove my C-3 thru a storm for 130 miles (Bowling Green heading back west) and was very comfortable with the C-3 brakes. They worked great. Yoko's worked good in the wet ,too.
Case In Point: Once in the 1970's, before ABS brakes, I was day dreaming while driving ..and at the last moment I realized I was driving into an intersection against a red light! I slammed on the brakes..there was the awful screetching sound of the locked up wheels and also large plumes of white smog billowing out of the car's wheel wells. Sliding into an intersection with the loud screetching sound and the plumes of white smoke was enough to alert everyone to brake to a stop. The noise and smoke stopped the cross traffic and no one hit me. In today's world with ABS, if I jammed on my brakes there would be no white rubber smoke and no screetching noise. For my 1970's situation, if I had ABS, I probably would have had a collision with someone. PROBLEM: WITH ABS YOU DON"T GET BRAKE NOISE AND SMOKE TO WARN OTHER DRIVERS!!!!
Another problem with ABS: I've noticed that if I'm heavily braking and I hit a chuck hole or a rail road track (that causes the wheels to bounce up and down and unload the wheels and perhaps allow them to momentarily stop) the ABS will disconnect. If you hit a road discontinuity (hole) and the wheels bounce, the ABS will disconnect for almost a second of time. This can be somewhat frightening and also very definately a safety hazard. The ABS on my Ford Thunderbird will disconnect for a second (half second?) ...disconnect means ..no brakes whatsoever. This no brake situation is really a dangerous situation.
you know i was thinking the same thing...the C4 suspension has so much to offer and with the ABS its a "complete package"....i like the C3 but even my Explorer is more comfortable to drive .....i wonder if i was driving a C4 i would feel the same way.
To each his own really on what they want out of a car and how they feel in a car. I myself do not like those additional items. But to each there own. If it will make you feel better and more comfortable to drive the car with the addition of that equipment I say go for it if it makes you happy.
From reading some talk from the c5 guys, it appears that you can basically threshold brake without the ABS kicking in. But once you get to the point of the brakes locking up the ABS will kick in. Seems like a good safety backup to bail you out of trouble if the unexpected does occur. http://forums.corvetteforum.com/show....php?t=1038992
