You'd need the ABS speed sensors in the hubs. There is no point. ABS is for those unable to drive. It is just unnessary weight and another thing to break. These are Corvettes... the last thing they need is another thing to break.
I agree with shmucker,
Why ?
1- alot of work to install
2- the cost $ $ $ $
3- you are going to pull down the value of the car, more than not
4- a computer does not know whats out in front of you , you my need them brakes locked up for a second or two to avoid something in front of you.
The corvette is a performance machine , I can stop alot sooner without abs than with it , infact I pull the fuse out on my cars and trucks that do have it, you have alot more stopping power without it if you know when to brake and when not to, to control the direction and stopping ability of your car .
ABS will not stop you as fast as properly executed threshhold braking. Pumping the brakes is for those who can't drive AND don't have ABS! Do yourself a favor and get some experience braking at the limit in various conditions, don't hack up the Vette.
The nay sayers haven't a clue what they are talking about. No one can out think a computer when it comes to speed and precision. If you think you can you're an idiot.
I did a lot of research on ABS and traction controll system about a year ago. It's really not that hard to plumb in a wire up.
I polled a bunch of C4, C5 and Porshe guys. It almost always came out the same way. They all hate it, ABS, ASR, traction control sucks...
except for that time in the rain, or another time on dry pavement when that old lady pulled out in front of them in her 72 Eldorado, would have been toast if I didn't have ABS...
Oh yea and my 1/4 mile time are better with the traction controll ON ( except for the burnout ).
In Short modern 4 wheel ABS with traction control and ASR make a modern car modern. It tames the wild moments. Even die hard racers leave the ABS on cause they know that if they feel it come on they're pushing too hard.
So like I said, bolting it on wouldn't be that hard, it's just a box with brake lines and sensors.
The problem is that you have to program the unit and develop the parameters to program into the unit. A C3 will NOT use the same parameter set as a C4! For that you need Bosh's help. I doubt they'd be interested in doing 1 unit, or even 10.
-Chris
What ABS can do that you cant is put all four wheels at threshold at the same time. You have to settle for the weakest link. ABS is also faster at sensing wheel speed changes, for each wheel. Which you can't.
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
I'd love to have an ABS system, fuel injection and air bags.....already added the rack and pinon and OD auto.... not sure the airbags and ABS is in the cards though....fuel injection though would be cool and is doable
ABS...you're joking, right? Take the car out on a rainy day and a quiet road and learn how to stop the car in crummy conditions. You'll find the C3 braking system very capable in the worst of weather! ABS would only f*%# it up.
I've got all the goodies: overdrive tranny, rack & pinion, perhaps even EFI one day. But ABS isn't anywhere on my list!
BTW: My daily driver has ABS. The wife's DD has ABS, traction control and god knows what else (it's a Mercedes). So I ain't blowing smoke here...
Threshold braking works great if you have an adjustable bias valve and know how to set it for the conditions you are in that minute. Unfortunately rain, sand, leaves are not on race tracks, so the dry settings won't work every time.
If you read performance car reviews, they always leave the ABS on, it's the traction control, skid avoidance and other "aids" that they find difficult to adjust to.
And locking the brakes does not make you stop faster, except on gravel or snow where the wedge effect helps. Rolling friction is always greater than skidding friction.
But to get it dialed in would be a monumental task, and you'd have to do a lot of trial and error work. But nothing is impossible given enough time and money.
Joe
i will have to agree with 427V8. i have a 2003 jette 1.8t and it has traction control and four wheel ABS and i can say that driving in the snow and on very rainy days taht both work awsome and probably saved me from sliding through an intersection in the snow and from locking up my brakes in the rain and and for those who say that they can stop quicker without ABS i will have to raise the flag on that one. im sorry but the ABS on my jetta can stop it on a dime and put my vettes brakes to shame. if thre was a way to put ABS on my 76 i would be all over it in a heart beat and traction control would be nice to have also. just my opinion
Thank you 427v8 for your insight. Guys, here is my car currently along with its engine. The frame is going to be full welded, gusseted and autoX prepped. At this point, I could care less about the cars possible decrease in value because of adding ABS on. Our brakes are fine in the rain up until you need to make that unplanned panic stop and the brakes lock up. Things get ugly really quickly then. Like 427 said, the fbody and corvette ABS monitors each wheel and modulate then independately, it is quite sophisticated. I cant individually modulate each of the wheels by myself
You can use the F-body stuff. You need to replace the entire brake system with an F-body system to get it to work properly. Master cylinder, booster, ABS controller, Traction controller, wheel speed sensors and you might as well do rotors and calipers while you are at it.
I
Rolling resistance is greater than skidding resistance - any time you lock up your wheels you lenghten your stopping time and distance. So if you panic and lock up your brakes you will slide further And just as an added benefit you will flatspot your tires - that makes for a really fun ride!
- you need to train yourself to brake to the skidding point - then back off slightly. Doing Autocross is a grat way to learn this skill - so is going to any of the racing schools out there.
Oh and ask me about hitting the grass on turn 1 at 105mph, sure coulda use some ABS then!
tell us about it. Not many people flog a C3 on a roadcourse. Going to the autocross and roadrace section gives me no joy. We need an ad-hoc C3 group discussion.
The C5 guys talk about just standing on the brake in every turn and just let the computer slow the car. Whats to point of racing if you let the computer drive the car?
Same reason you add more hp: to go faster, the name of the game is to be the fastest within the rules, if the rules allow ABS you would be an idiot not to use it if you have it. Why race cars if you think it is all about the human, why not just run foot races?
It's an older statistic, but it was generated when half the cars came without ABS. You couldn't do the analysis as easily today. Most cars have ABS nowadays because it does help idiots steer during braking...
