My new Big tires
Old Mar 18, 2005 | 08:09 PM
  #41
INTIMIDATOR ZO6's Avatar
INTIMIDATOR ZO6
Originally Posted by tzeller
Let's see ya turn those babys over.
Actually they will be easy to spin! I had a set of 33x21.50x15 Mickey Thompsons on my Pro Street truck.
Old Mar 19, 2005 | 06:25 PM
  #42
cruzzin-style's Avatar
cruzzin-style
Hey: As a guy who like the "biggies" (both on cars & women), I can tell U that your gonna have quite a time trying to fit those underneath the stock frame & suspension. Almost looks like a tub job. But, I guess if you go with the offset T/A's & use the much larger axle shafts, plus fender flares (wouldn't hurt) you might be able to "squeeze" 'em in. Also, what gear are you planning on running? If your're keeping the stock 3:08, those tall "monsters" will be dropping your ratio way down below 3.00:1 ratio. Good luck, should look "****" if you can get 'em to work.
Old Mar 19, 2005 | 06:39 PM
  #43
norvalwilhelm's Avatar
norvalwilhelm
No way offset trailing arms are going to help, nor a stock frame. He already said he is going to cut everything behind the seat out and do it right. It will look wild.
As for traction they are not very good, they are for looks not performance. One of our locals has them on a 55 chevy and everywhere he goes you hear this squealing sound.
They will make the looks all by themselves.
I hope you post alot on the project.
Old Mar 20, 2005 | 06:34 AM
  #44
SMH's Avatar
SMH
It will be tubbed. Probably put a 410 gear in it.
Old Mar 20, 2005 | 07:16 AM
  #45
ICEMAN59's Avatar
ICEMAN59
That is some serious meat I hope you get them to fit I have 275/50/17 on the rear with a 383 stroker 480HP and a 3:08 rear end and I have to power break to spin them. I get great traction and run a 3.9 0-60 and a 12.2 !/4 @ 122MPH with no wheel spin. I'm thinking of going to a 3:23 or 3:73 rear end to see what happens. Good luck!!
