Rotor setup
Old Mar 17, 2005 | 05:28 PM
GTR1999's Avatar
GTR1999
Default Rotor setup
removed
Old Mar 17, 2005 | 05:42 PM
norvalwilhelm's Avatar
norvalwilhelm
Looks nice Gary. Your usual beautiful job.
Old Mar 17, 2005 | 05:50 PM
NHvette's Avatar
NHvette
Nice job. I like the tapped hub deal.
Some moron used 1/4-20 bolts to hold the rotor to one
of my hubs ... ground the hex heads thin to fit in the rivet
recess ... then tack welded the nuts on the inside. Luckily,
it looks like they used cheap grade 3 bolts. So, where did you
find those 3/8-24 flathead sockethead screws ?
Old Mar 17, 2005 | 06:18 PM
Schmucker's Avatar
Schmucker
Originally Posted by NHvette
So, where did you
I think my mom sells them at her hardware store. I helped a guy find thin nylocksin 10-32 for the same style of screw today. So... check your local hardware store!
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
from the looks of that rotor, your car hasn't seen the road in quite some time.
what size drill did you use to countersink?
Old Mar 17, 2005 | 06:30 PM
NHvette's Avatar
NHvette
Is that a trick question ? .... you use a countersink .... of the proper angle and diameter.
Thanks Schmucker ... haven't seen these in sifting through the hardware drawers.
I'll look more closely.
Old Mar 17, 2005 | 06:42 PM
Twin_Turbo's Avatar
Twin_Turbo
I think the countersink needs to be a 82 degree one...if i remember correctly.
Old Mar 17, 2005 | 06:48 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
For metric bolts it's 90 degrees - it may be different for imperial bolts
Old Mar 17, 2005 | 06:52 PM
stpman's Avatar
stpman
Gary
did you use grade 8 bolts? how long of a bolt did you use?
Steve
Old Mar 17, 2005 | 06:56 PM
turtlevette
since nobody seems to know,
i guess it is.
Old Mar 17, 2005 | 07:08 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Unbelievable... it's different than metric....
Old Mar 17, 2005 | 09:43 PM
GTR1999's Avatar
GTR1999
The 3/8-24 socket flat head screws can be bought from MacMaster Carr .They're rated a grade 8,not that it's needed.
I used a countersink, not a drill bit on the rotor. Zero miles on the rotor, I just installed it on the hub today?
The car is in the middle of a body on resto.Every mechanical part on the car is being removed,disassembled, cleaned and rebuilt by me.The only thing I'm sending out is the block and crank,which when out this week. I'm in no hurry to finish the car. After 28 years of working on corvettes I don't care that much about driving them anymore. I actually like helping others fix their cars now more then driving mine.
I always have at least one on the road to drive when I want. Whenever I finish the car it will be better then it was when it left the factory. I already finished the tranny,rear end, rear T arms, front steering, steering box, front suspension,etc.
Gary
Old Mar 17, 2005 | 10:02 PM
Retro78's Avatar
Retro78
Nice work. Why are the rivets(or bolts in this case) needed? I do not have them installed on my vette and just wondering if I should be installing them.
Old Mar 17, 2005 | 10:03 PM
Steve's74's Avatar
Steve's74
Gary,
Does the POR-15 withstand the temperature that the rotors reach? If so, it looks like a good way to prevent rust.
Steve
Old Mar 17, 2005 | 10:09 PM
GTR1999's Avatar
GTR1999
The bolts the are not required. I like the idea of keeping the hub and rotor together and I didn't want to rivet them. You can use just the lug nuts.
The Wheel will rub the top coat off where it hit the hub. The POR15 will stay on the heat should not affect it. I painted them just because I'm ****
Gary
Old Mar 17, 2005 | 10:40 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
gary it looks good......if i were to measue my runout with the hubs not riveted or connected to the rotor would i need to put a nut on each stud and tighten them down? thks bob
Old Mar 18, 2005 | 06:48 AM
Steve's74's Avatar
Steve's74
Gary
Arent' we all?
Steve
To Rotor setup
Old Mar 18, 2005 | 07:01 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
There may be shims between rotor and hub to improve the runout - the rivets or bolts ensure that the rotor is tight against the hub. I'm guessing that this prevents the shim(s) from coming loose when you take the wheel off - the wheel studs would clamp it tight if the rivets/bolts were not there.....
I drilled my rivets out and did not replace them with anything, I'm wondering if dirt can get between the hub and rotor when the wheels are off and the rotor is 'loose'....
Old Mar 18, 2005 | 07:44 AM
GTR1999's Avatar
GTR1999
Bob you'll never get a true reading unless the rotor is secure to the hub. Even with it bolted together you have to use a soft touch not to jar the indicator. You can use all 5 nuts and evenly torque them to 40 ft/lb to check runout. Use chaulk or a china pencil to mark the rotor measurements.
Gary
Old Mar 18, 2005 | 08:45 AM
norvalwilhelm
You should drop by the shop and I could set you up with everything you need to indicate your rotors.
To do the back rotors properly you should disconnect the 1/2 shaft.
