I am currently working on a new project with my younger brother and we are thinking about installing a 383 stroker into his 1971 Chevelle. My brother is very knowledgeable in the automotive field, but I have limited experience.
At this point we have started to do the research and we have drafted a list of parts that we plan to use.
He is really excited about building the engine, but after I saw the price of the listed parts, I wanted to do some more research. I found several places online that could build a 383 for less than the cost of the parts.
Here are my questions:
Have a lot of members built a 383 stroker engine? What’s the difficulty rating?
Have a lot of members purchased a 383 engine? If so, did the company allow you to customize the engine?
Does anyone know a good, reliable company to purchase the engine from? Preferably in the Northeast, but I will take suggestions from anywhere in the US.
How much should I expect to pay for this engine if I build it or if I buy it?
Is there anything else I should be aware of?
All other suggestions related to this topic are welcome.
Thanks,
Joe
I bought my 383 from AR Racing in Virginia. There seems to be some mixed reviews about their engines. I would try Golen Engines, they're not too far from you, they're in New Hampshire. If I had known about them before I bought my motor, I probably would have bought from them.
Take a look:http://www.golenengineservice.com
Click "chevy hot rod", then click "carburated" or "fuel injected", then click "engines".
Thanks for the post!
It is funny you mention them. That is where I had my machine work done on my 327. They are pretty good, but I wanted to weigh my opptions.
Look at the GM Performance Parts catalog. They have crate 383 engines. I think they have warranties. Also, I believe that from reading all the postings, the GM Performance crate engines have really good comments from people that have bought them.
From reading this forum, I really believe that there are some engine building companies that are putting out engine qualities equal to or greater than GM Performance. Unfortunately, once again, from reading this forum I've read that there are some companies producing poor quality stuff. If you've got an engine rebuilder you're interested in, try to get previous purchaser's comments. GM is probably a pretty safe sorce, but they won't make a custom made engine for you. An engine rebuilder will build an engine that's just what you want.
I bought a ZZ4 Hot Cam. If I had it to do over, I probably would have had an engine built from a rebuilder. However, the ZZ4 Hot Cam, 400 real HP in a 2850 lb 1968 Convertible should be a good ride. (2850 lbs because I've got a lot of aluminum in the car.)
However, I don't think that they update their webpage.. Their performance engines are all listed on Ebay... However, they build custom engines to your needs/specs.. Custom built engines take a lot of time to be build, but they seem to be great quality... They are more $ than their Ebay engines, but I'd say that the extra $ will be well spent...
Now that, that is said and you still want a 383, then you need to speak to Rick @ HBR COMPETITION ENGINES in Las Vegas.
Mine runs on 93 octane, 525+hp, running mid 11s (easily), and with overdrive, I drive it wherever I want even out-of-state (and it's 4hrs just to get the hell outta here). Unbelieveably reliable.
I bought a 383 from Speedomotive in california for my 71 chevelle about 5 years ago and could not be happier.It cost me about $200 to have it shipped to indiana.At the time a long block cost about $2600.00 and the only thing that was used was the 4 bolt main block.It has new sportsman 2 heads,new crank,extreme energy cam,comp cams roller tip rockers,keith black pistons,double roller timing chain,and i had them add a 7 quart oil pan and harmonic balancer.You can have them build a 383 any way you want to fit your application.You can visit them at www.speedomotive.com or call them at 626-869-0270.
Hope this helps
Henry
