Destroyed U Joint pics......
Old Mar 19, 2005 | 01:51 PM
MsVetteMan's Avatar
MsVetteMan
Default Destroyed U Joint pics......
Well today I pulled the remains of the U Joint off the 81....
(For details of what happened see my "I can't get her started post".
The 1/2 axle is also worthless as it buggered up the ends enough so that is no way a new ujoint will go back in.
I'm rapidly gaining experience on the car! A little faster than I wanted, but......In the last two months, new rear wheel bearing, new distrib, new intake, new carb, new t'stat housing, ripped out old computer equipment, and now this! I'll soon have a little knowledge of UJoints and 1/2 axles........
Old Mar 19, 2005 | 02:14 PM
GTR1999's Avatar
GTR1999
Remember to bolt the flange to a solid plate before attempting to remove the joint from them or you'll be buying a flange too. Is the ID of the yoke ok , if so you might be able to reuse them. You're experiencing the reason many vette shops and vendors are wealthly today
Gary
Old Mar 19, 2005 | 02:34 PM
Twin_Turbo's Avatar
Twin_Turbo
there's no flange on 80-82, both sides have the caps/straps whatever you call them.
Old Mar 19, 2005 | 02:43 PM
GTR1999's Avatar
GTR1999
T.T - thanks for a correction
Gary
Old Mar 19, 2005 | 03:18 PM
MsVetteMan's Avatar
MsVetteMan
I ordered a new reconditioned 1/2 shaft with ujoints preinstalled...85 bucks.......should be here Monday, I hope?
Old Mar 19, 2005 | 04:03 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
thats gonna take a lot of JB Weld.
Well... SOMEONE had to say it.
Old Mar 19, 2005 | 04:05 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Thats my biggest fear
Old Mar 19, 2005 | 05:05 PM
Twin_Turbo's Avatar
Twin_Turbo
I'm building my own driveshaft loops, with the aluminium rods the halfshaft would take out a complete suspension corner...don't want that.
Old Mar 19, 2005 | 07:09 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
I'd clean that half shaft up with a dremel and put it back on the road.
Old Mar 19, 2005 | 08:25 PM
MsVetteMan's Avatar
MsVetteMan
I break everything!! Dremel is tore up as well! That thing didn't last two years.........
I'm keeping all of the original parts, so some other fool can tackle the job of the 1/2 shaft if they want. The round holes are beat up and bent more than it looks in the pics. Plus, it's a PITA to change out the u joint. I'm getting tired of PITA jobs........I'm passing on this one, especially if I can get a reconditioned one with the ujoints installed for 85 bucks....
To Destroyed U Joint pics......
