Heat Riser Question..
Old Mar 20, 2005 | 03:41 PM
Rhufus's Avatar
Rhufus
Default Heat Riser Question..
What is the downside of removing the Heat Riser on my '78 ? It is not driven in cold temperatures.
I am installing side pipes. I am not using headers, but coming off the stock exhaust manifold.
Old Mar 20, 2005 | 03:54 PM
pik's Avatar
pik
None that I know of. It is for helping starting when cold.
Old Mar 20, 2005 | 04:10 PM
Paul L's Avatar
Paul L
I would say none. Mine is welded open.
Old Mar 20, 2005 | 06:54 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
I don't think it will be a major problem, but the car will take longer to warm up. You do need either a heat riser valve or adapter on the right side manifold though, I don't think you will be able to make a connection there without one or the other.
Old Mar 20, 2005 | 06:57 PM
Captain_Kaboom's Avatar
Captain_Kaboom
Take'er off! I've removed mine and haven't noticed any difference. I actually went thru the trouble of replacing a broken one before just removing it...
Old Mar 20, 2005 | 07:49 PM
mvftw's Avatar
mvftw
Took mine off and went with true duals & H-pipe...
Old Mar 20, 2005 | 07:50 PM
Rhufus's Avatar
Rhufus
Thanx
To Heat Riser Question..
