I want to replace the 350 engine in my Vette. I have the short block from my 90 L98. Are there any issues installing this 90 engine in the 69 and mating it to the TH400 tranny?
I looked at complete engines, but I was thinking I can get get a good set of aluminum heads, a more aggessive cam (hot cam) and put this roller block together and have better performance for less cash outlay.
Going with a carb setup and Hooker side pipe headers. The computers are just too much trouble reprogramming the chips. Since it is a 69, I can stay with carburetion. I have an electric fuel pump and filter setup.
Suggestions or better ideas??? Thanks
Reason: Additional setup info
I've swapped a LT1's and am currently working on a LS1 swap. All modern engine swaps into C3's are worth while. Go with a overdrive tranny (auto or manual).
Dan www.vetteworksonline.com
Other than the flexplate must match the engine (1 pc vs: 2 pc rear seal) and there is no fuel pump boss on your late engine there are no issues. Are you going to keep the TPI or put a carb?
Corvette Fever is doing a series of articles called "Project Shark Attack". The original L48 will be replaced with an L98, but stroked to 383 CI. We want better fuel mileage so we will use a Holley 950 Commander TBI with a Holley intake manafold. Your carburetion should be just as easy to do with the plus of less valve cover leakage and the newer 1-piece rear seal. Using an 87-91 L98 also puts you into roller cam territory for increased efficiency. Sourcing cylinder heads should be relatively easy. Have them re-done with a 3 or 4 angle valve job and a little pocket porting. With the right camshaft choice you can build plenty of torque and HP rather easily without breaking the budget.
