Installing starter, How to Shim?
Old Mar 22, 2005 | 01:50 PM
mandm1200's Avatar
mandm1200
Default Installing starter, How to Shim?
I got a new starter which came with a couple of shims and mounting bolts. The engine is still on the stand. How do I go about installing the starter? By that, I mean what do I look for in regards to the flexplate and starter teeth. Is this something that is critical or do the shims allow for a better/proper installation.
Old Mar 22, 2005 | 02:16 PM
Steve439's Avatar
Steve439
It's pretty important for mini-starters, I don't think I've had to shim
a stock one. I can't remember the exact fit to look for. I think being
able to just fit a large (about 1 1/2 inch) paper clip between the teeth
of the starter and the flexplate is about right. That's with the starter
gear extended. On my 427 I had to cut a thicker shim out of some
aluminum plate to get it to work right.
Seems like I remember norvalwilhelm talking about moving the starter front to rear too. I've never had to do that, but you might PM him. He's a real helpful guy.
If I'm wrong about the clearance hopefully somebody will chime in...
Old Mar 22, 2005 | 02:38 PM
jimvette999's Avatar
jimvette999
It's a good idea to retain your old starter nose and transfer it to the new starter. It usually means you don't have to do any shimming. You may not need the shims that are supplied with your new starter, you'll know by the sound it makes when you try and crank it over. If it sounds harsh when you try it, add the thinnest shim and retry it. That's my opinion.
Jim
Old Mar 22, 2005 | 02:53 PM
mandm1200's Avatar
mandm1200
Originally Posted by jimvette999
It's a good idea to retain your old starter nose and transfer it to the new starter. Jim
The new starter is a mini starter, so tranferring is out of the question. I would assume there should be a little room between the gears for them to mesh.
Old Mar 22, 2005 | 03:02 PM
LOTAHP's Avatar
LOTAHP
This is an excellent time to see how much you need to shim the starter. You need to mount the flywheel or flexplate to the engine and mount the starter to the block. There should be directions showing the teeth pattern when engaged. You can engage the starter to the flywheel carefully using pliers and see what you have.
Old Mar 23, 2005 | 01:41 PM
TJ76's Avatar
TJ76
If I remember right, you need to be able to fit a 3/32" drill bit between the tip of the gear of the starter (when extended) and the flywheel, this will give you the proper clearance. That is what the shims are for.
TJ
Old Mar 23, 2005 | 07:48 PM
glen242's Avatar
glen242
If you go to the Jeg's web site, there is a page, in their tech section I believe, that tells you how to check starter alignment. Sorry, I don't have a link, I just printed out what was there. The article is titled "Installation Instructions for 10001-04, 100200-22 & 10040 GM Starters".
Old Mar 31, 2005 | 09:10 AM
mandm1200's Avatar
mandm1200
Thanks!
I found the instructions. If anyone else wants to take a look, here is the link http://www.jegs.com/instructions/555...1-04-20-40.pdf . It amazes me how there are so many little things come up when building an engine from scratch.
To Installing starter, How to Shim?
